Results 1 to 7 of 7
Thread: start up with scaling
    So i started up BBB for 2nd years in a row,I notice i have some rough/scaling on side of pool below water line to bottom,only on sides.U cant see in only feeling it.Kids jump in pool and said bottom was smoth.
    What should i do first are wait till pool get clear? water is clearing started 3 days ago.thanks
    24' AGP sandstone,12,000 gal , cricupool rj30 SWG,fas-dpd test kit. BBB
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: start up with scaling
    Quote Originally Posted by bullet20
    Pretty much. You can't really get an accurate pH test until the chlorine level is down below 10.
    Get the water cleared up and then get and post a complete set of water test results.
    I just tested tonigt
    7.5 fc
    1.5 cc
    7.4 ph dumped 1/2 gal acid at noon was at 8.0 and up
    40 cya was a 0 just put about 5 lbs yesterday and today in stocking.
    water is clearing light blue but a lil cloudy,thinking about putting back at shock tonight or wait till morning? thanks a head.
    38,426
    They are going to want the CH numbers also to see if you were in a scaling condition.
    Richard320's Avatar
    Jan 2010
    19,046
    7.5 fc
    1.5 cc
    You need to keep shocking until
    CC is 0.5 or lower;
    An overnight FC loss test shows a loss of 1.0 ppm or less;
    And the water is clear.
    Quote Originally Posted by jblauert
    CH 300-350
