Results 1 to 7 of 7
Thread: New to TFP
    Mar 2008
    New to TFP
    Hello everyone! I am new to this site. I was referred here by ChemGeek. I am a APSP Certified Service Professional operating out of Bethesda MD. I have found these forums very helpful, especially with water chemistry. I have been to Tech 2 pool school and taken numerous advanced water chemistry classes. Alot of the stuff I've learned here wasnt even mentioned in these classes (such as maintaining Free Chlorine 10% of CYA). I've also completed Jandy, Raypak, and Pentair technical schools and am always looking to advanced my swimming pool knowledge. This is a great site!
    Mar 2007
    Coastalish 'down easter'
    Muss, it's my pleasure to welcome a 'brother in pools' to TFP!!
    I hope you won't mind my picking your brain from time to time as (for some reason) all 4 of the companies I've worked for have used primarily Hayward products - so I'm a little lacking on the Pentair and Jandy products that I run into a couple of times each season
    Again, welcome here!! I hope that you will not only use this site as a resource for learning, but also contribute from your knowledge/ experience
    Ted (aka - waste)
    Luv& Luk
    Butterfly's Avatar
    South Carolina
    Welcome to TFP!
    You're done SLAMing when:
    Dec 2007
    Central New York
    Welcome to the forum, muss08.
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Greetings and salutations!
    Welcome to TFP!
    it is always nice to have more professionals here to assist our members with their pools!
    8000 gallon 20' x 48" round vinyl frame pool, 12" sand filter (don't have the specs on the pump), TF100 test kit
    Handy Links: PoolMath, TF-100 Test Kit, Pool School, CYA-Chlorine Chart
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    Once again, thanks to Chem Geek!
    Oh, and welcome to TFP!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
