Thread: DE to Cartridge Advice
    Guest
    Hello, First post here.
    I have had my pool for over 13 years now and have just started to develope a couple of leaks. I have replaced the pump recently and some o-rings in the valves, but have a nice leak in the manifold to the filter. The DE4800 still appears to be working fine, but the filter powder has become a bit of an issue (homeowners association!).
    While replacing the manifold I have decided to swap to a cartridge filter and am looking for any advice on the matter. After my research I have decided on the Hayward Star-Clear Plus C1200, as I think this is an adequate replacement. Does this this seem like the right option and size to use to replace it and I am I making this too simple or are ther ather factors I am not considering?
    I appreciate any feedback you have-thank you.
    Playpool with waterfall approx 9800 gallons
    Navigator cleaner
    DE-4800
    IG Pebble Tec
    2 HP Pump
    96 GPM flow rate (according to filter)
    Feb 2008
    Denton, TX
    5,061
    Re: DE to Cartridge Advice
    Welcome to TFP! Someone who is well-versed in filters should be along shortly to advise you on your choice.
    That filter is adequate, however I recommend getting a larger filter if you can afford it. Larger filters are nice because you can go longer between cleanings. There is also an issue with your pump being oversized. A larger filter would be able to handle the larger pump with overall higher efficiency.
    You might also want to think about replacing the pump with something smaller. A 2 HP pump uses a lot more electricity than a smaller pump would. I don't see anything in your pool specs that gets any advantage from the larger pump.
    Guest
    Thank you for the quick response. I appreciate your advice and will look to upsize the filter, but don't really want to replace the pump at this time (cost). thanks again.
