Thread: pool pad
    pool pad
    I'm going to put an agp on a slope. I had a pad dug out last summer so all the dirt would be settled and packed by this spring, but I just realized we went about 6" too deep . I know the pool is supposed to be installed on hard ground, so I was thinking about adding back about 6" of chert, which packs very hard and quick. I'm about 1 1/2 months away from install so it will be settled by then, and I'll pack it when we level it. And since I'm going up all the way around and not just on one side, I don't see any problems with this. Any opinions?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: pool pad
    Do you already have the liner? If not why not just order it to fit the extra depth?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Nov 2011
    Moberly,MO
    1,010
    Re: pool pad
    dbr25 I don't know where you are but building a pool on any backfilled dirt is a really bad idea. Dirt will settle for years. At least in my part of the world. We recommend rock if you have to fill an area to install a pool.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    22,553
    Re: pool pad
    db, Read through a bunch of the install threads and you'll see what other people have done. A pool full of water weighs in the hundreds of thousands of pounds (Mine weighs 108,000). You don't want that shifting.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: pool pad
    PS - neither do your neighbours!
    Re: pool pad
    Depending on your make and model recessing 6" below grade might not be a big deal. Just factor in a french drain to keep the rain and overflow from collecting against the pool.
    Or you could put your posts on block and then fill the pool pad with sand 6". Sand, once in place doesn't need to be compacted.
    When the only tool you have is a hammer everything starts looking like a nail.
    Doughboy 16x24 "Aboveground Inground" in progress...
