Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: variable or 2-speed
    variable or 2-speed
    New member here. I have read a lot on this forum, but still can't figure this out. Looks like the variable will be $550-$700 more. We have an older passive solar on our 1 story roof right near the pool. We pay up to .33 in summer and .23 in winter (ack) for PGE (we have a well pump too). I wouldn't mind going for it and buying a Pentair VF *IF* I thought if would last or had a 3 yr warentee at least. Such a gamble! Wish I knew the fail rate. If you look on Amazon there are loads of unhappy folks. Advice? Thanks!!!!
    17K gal, IG, plaster, DE, flow rate 72, Hayward 1.5 HP, Booster 3/4 HP, Polaris, solar 1 story, 2 1/2" pipe, Santa Rosa CA
    22,553
    Re: variable or 2-speed
    With that kind of electric rates it's worth going with the variable speed pump.
    We haven't heard about a lot of failures here and if it was a problem I think we'd hear about it.
    mas985's Avatar
    Pleasanton, CA
    11,742
    There is a lot of anecdotal evidence for the failure rates of any pump. It is just big unknown which is why I started this thread just to see if conventional wisdom was true.
    Also, you can get an Intelliflo VS (011018) for less than $900 and it has most of the features of the VF including timers which is all you need really.
    One thing that can help is a cost benefit analysis to determine exactly when payback will occur. If it is less than the typical life of a pump, then it is all gravy after that.
    So if I assume the following:
    17k pool
    0.5 turns/day in winter
    1.5 turns/day in summer
    1 turn average per year
    25% on high speed
    75% on low speed
    Assume the same flow rate and run time for both pumps (sub optimal for the Intelliflo)
    Average electrical cost of $0.30/kwh
    Whisperflo WFDS-24 cost of $550
    Intelliflo VS cost of $90 - $100 rebate = $800
    Here is the lifetime costs after 60 months of operation:
    Whisperflo WFDS-24 = $1779
    Intelliflo VS = $2002
    Even assuming that the Intelliflo has the same flow rates as the Whisperflo, the intelliflo will overtake the Whisperflo in about 5 years as being more cost effective than a two speed. After that it is a bonus.
    Either a two speed or VS speed would be a good choice but the VF will take much longer to be cost effective (~10 years) than a two speed and it will never be more cost effective than the VS.
    Mark
    Great data Mark! Lots to think about. Glad to see the Pentair isn't the problem that I thought from reading Amazon reviews...Thanks.
    I think we will go with the variable speed pump. Can we then get rid of our (too powerful) Booster pump to run sweep, but only run sweep for 1 hr a day or so? Would that then be 3 power levels needed, low for no solar, med for solar and high for solar with sweep?
    Does the timer on the pump work this way or do we need to add a controller?
    Thanks so much for your help!
    mas985's Avatar
    Pleasanton, CA
    11,742
    With all the various modes that you need, you might want to consider a controller to go with the Intelliflo. It will increase overall cost but probably make you life easier. BTW, how do you control solar now?
    Mark
    We have 2 timers to control the pump and sweep. We have manual switch to run through the solar. I'd like to not buy the controller yet unless we need it. Just spent a bunch on insulation and energy upgrades for our home. Would like to buy the controller later if possible. I have to sell this new bunch of pool upgrades to the hubby in smallest chunks possible Thanks!
    mas985's Avatar
    Pleasanton, CA
    11,742
    The Intelliflo 011018 has a built in timer and speed settings so you can run the pump that way.
    Mark
    Thanks Mark, you are awesome!
    PB says Intelliflo VS, get rid of the booster for the sweep. Will run at setting 2 (1500 rpm) thru solar. Will push sweep too for a hr a day. Then in August when the pool is too hot we will manually bypass the solar and set the pump setting 1 to (900 rpm) to save more money.
    Is 1500 rpm enough to run the solar and sweep too? I have read on this forum that the VS is less efficient at higher rpm, don't want to end up with higher energy bills...
    38,520
    Quote Originally Posted by flyingchanges33
    I am not an expert, but I think the efficiency goes down, but still likely less power than your current pump at full speed (~3000 rpm).
    I have read that the solar heating efficiency is higher with larger flow rates, you may be able to run at speed 2, but the heating may not be as much as you could get at higher flow rate. I think the rule of thumb for the panels is around 0.1 GPM per sqft of panel.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Solar will definitely reduce your cost savings but that is part of the price of solar. The good news is that since solar is on a 1 story roof, it is much better than a 2 story roof. Trial and error is probably the best method to get both the solar and cleaner to work.
    Also, the good thing about the Intelliflo is that you can set the RPM for just enough flow rate, whatever than may be, and optimize the energy use. A standard pump you would have to run on high speed and you get what you get so because of this flexibility, the Intelliflo will still be more efficient.
    Mark
    Going with the Intelliflo VS 011018, whew, thanks! Now we are optimizing. Going to add an actuator to switch sweep on/off with timer. Can the pump switch speeds with automation? If so, will the SunTouch handle changing speeds and running an actuator?
    Feb 2012
    Phoenix, AZ
    728
    Yes, the Intelliflo can switch speeds with automation. The sun touch will be able to change pump speeds and control the actuator.
    Great! Thanks Blake! Hubby tells me our DE filter cleanout port is broken...so new filter might be a good idea. Hubby is loosing the purse strings a bit I heard Pentair will give 3 yr warrenty on pump if you buy 3 of thier pieces. So looking at PacFab DE. Sound good? Does the SunTouch and/or actuator count as a third item?
    Feb 2012
    Phoenix, AZ
    728
    Yes, Pentair will offer a 3 year warranty if you buy a pump, filter, and one other item. I do not think an actuator would count as a third item, but a SunTouch would (and you could get the Suntouch that includes an actuator). You DO have to buy these items at the same time to get the longer warranty.
    As for a filter, PacFab was acquired by Pentair, so they no longer manufacture filters. If you want to go the DE route, I would suggest a Quad DE.
    So who handles Pentair warranty if I buy my new pump, filter and controller online instead of through my PB? PB will still install.
    22,553
    The local Pentair service center will handle the warranty. That may be your local dealer as well.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    I moved out of CA a couple of years ago, but back then I recall PG&E offered rebates for people who bought variable speed and 2-speed pumps. I don't know if they still do, but its worth looking into.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
  20. Back To Top    #20
    PG&E California has a rebate or $100 for variable speed pumps and $100 for controllers. Some other states are higher.
