Thread: Structure to make a deep end shallower
    Feb 2012
    San Jose, CA
    76
    Hi everyone! I'm currently trying to decide between a standard shallow/deep end pool, and a sport pool (shallow on both ends, slightly deeper in the middle), and was wondering if I could have the best of both worlds by building the former, and when it's time for pool volleyball, to insert a structure in the deep end to convert the pool?
    Has anyone ever seen such a thing? I saw this thread insert-to-make-pool-more-shallow-t24737.html from a few years ago which seems more geared towards toddlers. Thanks!
    Peter
    Filled 5/1/2013! 36k gallon 20x40 IG with 7x7 spa, FinestFinish, AquaMatic cover, All Pentair: Clean&Clear 520 sqft cartridge filter, Intelliflow 4x160 variable speed pump, 2 HP whisper flow spa jet pump, 400k BTU MasterTemp heater, Letro Platinum pool cleaner, Rainbow 320 chlorine feeder, Pac Fab Bermuda skimmer
    More details: pics-new-pb-20x40-ig-gunite-7x7-spa-7x7-shamu-shelf-t54952.html
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Structure to make a deep end shallower
    I don't think it would really be practical, given how heavy and ungainly it would need to be. The solution is a bigger pool with areas for both
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I don't see how you could just quickly insert the structure, most likely it would be a semi-permanent deal, unless you had a crane....Or it was attached to pivot points on the deep end of the pool decking, and you could just flop it in and then wench it back out....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Feb 2012
    San Jose, CA
    76
    How about a collapsable structure? For example, pipes that fold into themselves?
