Thread: how to figure out which Swimquip S​ta-Rite skimmer I have?
    I'm trying to determine what skimmer type I have on the pool that came with my house. Removing the basket, I see 8560-87, which suggests to me it is part 8560-8, which fits on a Swimquip S​ta-Rite Pool Skimmer.
    I don't know which exact model I have. How would I determine this?
    I would like to find a vacuum plate to fit this skimmer, or some other way of measuring suction at the skimmer-side port.
    60k gallon (est), 83ft PebbleTech pool, spa. Goldline Aqualogic controller, AQL-PS-8. 2 Hayward SwimClear C5025 filters. Hayward H400ED2 heater. 2 T-15 SWG. Pool pump: Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor. Spa pump: Hayward SP4015NS pump / 1.0 HP Emerson 1081 motor (SF 1.4, RPM 3450, Amps SF 6.2-5.8/11.6). Hayward 5060 3/4HP booster pump. 6' x 9' waterfall driven by a Hayward SP4015NS pump (115 GPM @ 47' of head & 2200 watts). Spa jets driven by a Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor (SF 1.6, RPM 3450, Amps SF 11.0 - 10.2/20.4) Still learning!
    Re: how to figure out which Swimquip S​ta-Rite skimmer I hav
    I think that you have a Sta-Rite U-3 Skimmer. Does the basket look like the one below?
    http://www.kaboodle.com/reviews/sta-rit ... 08650-0007
    Parts list:
    http://www.pentairpool.com/pool-owner/p ... er-216.htm
    I think that the below skim-vac would work.
    http://www.poolandspastuff.com/SkimmerP ... 0-0042.htm
    I think that this one would also work.
    Hayward SP1106 Large Skim Vac Plate
    http://www.westwoodpools.com/Hayward-SP ... 1400.html#
    What is the diameter of your skimmer basket? I'm thinking that it is about 8.375" in diameter.
    http://www.poolpartsonline.com/p-84114- ... skets.aspx
    Support the site
    Thanks James. I replaced several of the baskets when I moved in, which looked pretty much exactly like the ones in your picture. Attached are a few more pix with measurements. Is this unambiguously the U-3?
    I need to try to take a suction measurement at the skimmer, which will demand a plate with a threaded 1/4" fitting for my vacuum guage, or a plate with an integrated gauge. Or perhaps I could figure out some way to fit such a gauge to the end of a standard pool hose. Anyone know if there are such plates available for my skimmer or for a standard hose? I've googled a bunch and haven't found anything.
    I am pretty sure that it is the U-3 skimmer. What are you trying to figure out with regard to the suction? There are several options depending on what you are trying to do.
    Perhaps the below item will work for you.
    http://www.aqua-man.com/row_num.asp?Ic=1500
    Support the site
