Results 1 to 7 of 7
Thread: Picture Pefect, almost..
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    I opened my AG this weekend. It was crystal clear and beautiful. I've had it covered all winter, but still ran it every two weeks for about 4 hours and put some liquid chlorine in it each run. Opened it up, the PH is perfect, the Chlorine needs to come up a bit, but its perfectly clear. Ran the vacuum just to test it, and ran the pump for about 6 hours.
    The only issue I have, someone (I guess myself since I'm the one that cleans the pool) left a hair pin in the pool, and no I'm not the one that wears them. It rusted a bit, I tried to scrub it up, but the stain is there to stay. My concern is with the vinyl liner, will the rust eat throug it? Its on the very bottom, so it would be a pain to put a patch on.
    Richard
    Pool - 18' Doughboy Above Ground Vinyl, 7600 Gallons, 1HP Hayward Power-Flo Matrix pump, Hayward Star Clear Cartridge Filter C500 50 GPM flow rate, Hasa Chlorine Injector, Pool Rover Vacuum, Taylor K-2005 Testkit - Hot Tub - Artesian Pelican Bay, 550 Gallons, Ozone, Nature 2 Mineral Sanatizer, Bromine floater.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Picture Pefect, almost..
    Quote Originally Posted by rwrogers11
    Not sure if this will work on vinyl, but people on here have mentioned using crushed vitamin C tablets put in a sock and then placed on the stain. I would think it is worth a try. I doubt the stain will eat through.
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Hmmm, I'll try that. Just crush them up, put in sock, and weight down over the stain. I can and will try it. Thx.
    Richard
    Apr 2009
    Burlington, ON, Canada
    344
    I had a bag of steel wool blow into my pool last fall. Some of the fibres left stains on the fiberglass steps. I went to the drug store and bought Vitamin C and placed the tablets right on top of the stains. A day later they were gone. You could try this (I'm not sure..maybe the sock method works better??? Also, make sure it's pure vitamin C, ascorbic acid..don't get chewables or flavoured or anything like that. If you can get pill not capsule, even better.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Jul 2009
    London and France
    574
    Even if it doesn't work you'll still have much sweeter smelling socks
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Hehe, and I need that
    Richard
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, the vitamin C should clean it right up.
