Results 1 to 11 of 11
Thread: intelliflo vs intellipro variable speed pump
    We contracted to install a intelliflo variable speed pump but the contractor installed us a intellipro. They said the two pumps were identical but intellipro has a slightly larger basket and more easy to remove the motor if needed. I don't feel these are useful to me because we usually empty basket frequently and we will use service company if need motor repair. To me, besides the fact that intelliflo's almond color matchs our existing equipment color, I'm also concerned that IntelliPro is less known and has more possibility to get discontinued or more expensive if need to replace parts. Want to get the opinion from pool expert here whether my concern is valid. Or if you know one pump has an advantage vs another. Thank you very much!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: intelliflo vs intellipro variable speed pump
    Parts should be just as easy to find since they both use the same drive and the performance of the two pumps is nearly identical so the only real difference is the color.
    Mark
    Feb 2012
    Phoenix, AZ
    728
    mas is correct, you should be just fine with the IntelliPro!
    Edit: the programming on both IntelliPro VS 3050 and IntelliFlo VS 3050 IS the same, but the Intelliflo 3050 is no longer available (and was replaced by the IntelliFlo 3HP VS - sku 011018). This new IntelliFlo has 8 speeds, while the old IntelliFlo 3050 and IntelliPro 3050 each have 4 speeds.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The Intellipro and Intelliflo come in exactly the same equivalent versions and their programing interfaces are identical so there should be no difference in programming.
    Intelliflo VS-3050 <--> Intellipro VS-3050
    Intelliflo VS-SVRS <--> Intellipro VS-SRVS
    Intelliflo VS (new) <--> Intellipro VS (new)
    The only exception is the VF. I have not seen nor does Pentair advertise the Intellipro VF
    Mark
    Jan 2012
    340
    We install the Intellipro VS almost exclusively. In fact, the only time we don't is if the customer specifically requests intelliflo or we don't have one in stock. The pump has unions so any leaks that may occur are fixed easily usually by tightening the union (no service call for you to pay for someone to redo fittings on your pump) and, IMO, the pump design is better. I think the whisperflo seal plate design has some serious flaws. I cringe when I go to fix one because 8 out of 10 have the inserts pulled out of the seal plate and it's cheaper just to buy a new pump than to put all back together with parts. I'd say they did you a favor by putting the intellipro in. Performance is basically the same and I'm pretty sure the intellipro is a newer design, so I definitely wouldn't worry about parts going away.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Quote Originally Posted by thepoolman
    is this the reason why the intelliFLO on sale here? i hope that buying a new pump comment was just for the WhisperFlo.
    http://www.poolsupplyworld.com/poolsupp ... 011018.htm
    Outdoor (60% shaded) 22,000 gals: Mosaic tiles (concrete grout), 011018 IntelliFlo VS, Clean & Clear Cartridge Filter CCP320 filter, IntelliBrite 5g LED, Prozone PZ2-4V, Blue Devil 8way Tester, Taylor FAS-DPD Chlorine Tester K-1515A (you need this period—OTO is pretty much useless)
    Jan 2012
    340
    I was referring to the design of the whisperflo/intelliflo. To be honest, most people on here don't abuse their equipment and won't have the type of issues that I'm describing, but it can happen. The intelliflo is a great pump. Install it with some beefy cpvc nipples to avoid leaks and make sure it doesn't run dry and you'll be good to go. I just prefer the intellipro because I may be out later to deal with an issue.
    Blake can probably chime in as to why they are on sale. I'd assume it's the result of an early buy purchase or something and they are passing on savings. To my knowledge the intelliflo isn't going anywhere.
    Corresponding models of the IntelliFlo and IntelliPro are nearly identical. The largest differences are in the superficial details like the paint color, brand labeling, and unions. The motor and electronics are identical between the two lines and while the wet ends are different, that doesn't have much effect.
    Jan 2012
    340
    The max-e-pro and whisperflo were designed by two different companies at two different times. Although their performance is comparable, they're pretty different.
    Regardless, either pump is the VS version is a good choice.
    susa's Avatar
    Oct 2010
    Deep South
    578
    Which model Intelliflow in contract ?
    If VF, contractor owes you a replacement
    Feb 2012
    Phoenix, AZ
    728
    The Intelliflo VS-3050 was replaced by the Intelliflo 3HP VS (sku 011018). The only significant difference is the new pump has 8 speeds. It is not 'on sale,' just very competitively priced. That is a great pump and it's not going anywhere!
