Results 1 to 19 of 19
Thread: Air Temp = 197 degrees F?
    May 2009
    Rocket Town, AL
    49
    Goldline system, air temp sensor either reads, "Short" or most of the time a reading near 200 degrees. Looking at where the sensor connects to the board, I see no short.
    Water temp sensor is accurate.
    How do I troubleshoot?
    18x36 In-ground Vinyl, 24,000 gallons.
    Sand Filter, 1hp Hayward.
    SWG
    Polaris 280
    Ft Lauderdale, Florida
    1,455
    Re: Air Temp = 197 degrees F?
    switch the two sensors (which should be similar) at the circuit board and see if it flip flops the displayed temperatures.
    If so, I would say that your air sensor is bad.
    If not, and it still shows the water temp as short or high, then you've most likely got a problem on the circuit board.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    May 2009
    Rocket Town, AL
    49
    Copy. Thanks!
    SWG
    Polaris 280
    May 2009
    Rocket Town, AL
    49
    So I did the swap yesterday...
    Before the swap:
    Air = 197F
    Water = 72F
    After the swap:
    Air = 68F
    Water = -11F
    Here are some interesting observations:
    Both sensors use red/black wires. One sensor was arranged with red on top, the other black (Possitive/Negative neutral?).
    And here's the biggest kicker. According to the words on the circuit board, the sensors were wired into the wrong
    position!
    SWG
    Polaris 280
    Curious. The problem followed the sensor, but switched from a near short to an open circuit.
    Which wire from the sensor goes to which side doesn't matter, i.e. red and black are interchangeable.
    May 2009
    Rocket Town, AL
    49
    Could you explain further? What I did proved that the air sensor is bad, no?
    SWG
    Polaris 280
    No, unfortunately. You have proved that the originally wired to the water connection, and now to the air connection, sensor is working correctly.
    A bad sensor will show as either consistently too high, or constantly too low. Yours switched from too high in one configuration to too low in the other configuration, which suggests a problem with the wiring. The problem could be a bad connection where the wires connect to the main unit, or an intermittent connection somewhere along the length of the wire, but is unlikely to be a problem with the sensor it's self.
    May 2009
    Rocket Town, AL
    49
    Interesting. What next?
    SWG
    Polaris 280
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    PhotoEd, these are the values for pentair temp probes. Measure the resistance of the probe, use the air temp. as your known value. If you can't read it let me know.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    1,455
    I do agree that it proves the original water temp sensor is working correctly, as well as the pcb terminal connections.
    how do the wires look? frayed? discolored? perhaps cut the wires back about a foot to get a fresh contact point on the wires.
    otherwise, I would replace the air temp sensor and call it a day.
    May 2009
    Rocket Town, AL
    49
    I inspected the full length of wire and it looks unharmed. How does one spec. out a new sensor, or are they all the same?
    SWG
    Polaris 280
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Ed, did you measure the resistance of the sensor?
    May 2009
    Rocket Town, AL
    49
    Not yet.
    SWG
    Polaris 280
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Is it a Goldline sensor? Usually black probe with tan wire. I've had 2 go bad on me doing the exact same thing as yours.
    May 2009
    Rocket Town, AL
    49
    Yep! That's the one!
    On line supplier? I'll check with ohm meter before buying.
    SWG
    Polaris 280
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I'll check tonight Ed and see if I still have the number. Measure it first though to make sure it is in fact the sensor. I believe it was a little spendy? $35-40 if i remember? I would cut off the stripped ends and strip new ends and measure from there.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Ed, I've looked high and low and I can't figure out what I did with my sensors! Did you ever get it fixed?
    May 2009
    Rocket Town, AL
    49
    Hoping to look into it today, thanks for checking!
    SWG
    Polaris 280
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Ed, found it! This is the number for the kit!
