Thread: Cleaning the Cell
    Aug 2008
    Hebron, CT
    79
    Cleaning the Cell
    My SWG cell doesn’t appear dirty. However, in getting ready for the upcoming season I thought I would clean it. The manual says to use either distilled white vinegar or 10 parts water and 1 part Muriatic Acid. I chose the acid thinking it would be a more thorough cleaning. The directions say to wait for the foaming to stop after about 5 or 10 mins and then dispose of the acid carefully or put it in your pool. It never foamed at all. Even after shaking it, it never foamed. Did I do something wrong or was my cell just not that dirty? Just wondering if I actually did anything to clean my cell? Any opinions?
    Thanks!
    22,500 gal Lagoon shaped inground pool, vinyl liner, Hayward 4800 DE Filter, Hayward 1.5 HP super pump, Aqua Heat Pump, Nexus Pure SWG, Dolphin Triton PS, Hebron, CT
    Nov 2011
    Magnolia Texas
    80
    Re: Cleaning the Cell
    Was there any build up of scale or calcium in your cell? That is what the muriatic acid is dissolving (putting back into solution) when it's foaming or making bubbles. Good chance you didn't have any. Ours started scaling badly when the CH got above 400 ppm. It actually was at 600 ppm and I couldn't keep the calcium off the cell then. My solution was to drain and refill the pool after 7 years. Now CH is 240 ppm and the problem is solved.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Aug 2008
    Hebron, CT
    79
    Thanks for the reply. From what I could tell, it didn’t appear too dirty, but I had never cleaned it before with acid. There has never really been any visible scale build-up over the years. Also, the CH in the pool is always quite low (below 100ppm)
    Nov 2011
    Magnolia Texas
    80
    As long as everything is in balance with that low of a CH you probably won't ever have to worry about scale. I've got a plaster pol so I have to keep my CH higher.
    DE Filter
    Aug 2008
    Hebron, CT
    79
    Thanks for the help
