Thread: pH Calibration Error
    Oct 2008
    Bonita Springs, Florida
    84
    I'm using the Hayward Sense & Dispense system with a Goldline Pro-Logic controller. I adjusted the pH level in the Maintenance menu from 8.0 to 7.8 and now I'm getting the "pH Calibration Error - Check System" message. The manual states that I will get this error if the test result is different from the measured level by +/- 1.0 or more or I need to clean/replace the probe. I have cleaned the probe and since I got this error after I adjusted the test result by 2.0 from the measured level, I'm guessing that is why I'm getting this error.
    I tried turning the Pro-Logic off; removing the BNC connector for the pH probe on the Sense and Dispense and waiting 24 hours for the system to timeout and turn back on and I still have the error being displayed.
    What do I do to remove the error message?
    Thanx.
    SW FL, 19K IG with spillover & cage, Goldline Pro-Logic PS-8, Hayward Sense & Dispense, Hayward Swim Clear 4025, Hayward Ecostar VS pump, Stenner MA pump, Aquabot, Hayward Aquarite SWG, Palin Pooltest 9, Helicol Solar.
    Re: pH Calibration Error
    Try resetting the PH calibration to factory default and see what happens. Also, if your PH probe isn't brand new, you may need to replace your PH probe.
    Oct 2008
    84
    Jason -
    I entered another pH reading this morning and it was accepted; the error message was cleared.
