Thread: Newbie.. just bought a house with an indoor pool
    Hi I just bought a place with an indoor pool that uses Bromine .. I ave always had an outdoor pool first on chlorine and then salt water.. so am looking for tips on care and general information with regards to an indoor pool using Bromine.. this pool also has a Dry-o-tron dehumidification/heating system ... We have to replace the liner for this pool and i am wondering if we should convert it to a saltwater pool
    Any suggestions are welcome
    thanks
    22,553
    Re: Newbie.. just bought a house with an indoor pool
    We're biased here so most of the suggestions will be to go with the swcg. That's what I suggest.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    mmmmm indoor pool. yummy.
    I cant wait for the day when we can build force fields that will keep stuff out of the pool yet still allow glorious sunlight.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Some of the simplicity of using a SWG is lost indoors, so it isn't instantly clear which approach is best. Outdoors it is difficult to run the SWG too much, as sunlight will burn off excess chlorine. Because of that the SWG percentage can be set anywhere near right and everything works. Indoors, you need to test regularly and be constantly adjusting the SWG percentage to prevent FC from going too high. Still, even with that I would prefer a SWG.
