Results 1 to 9 of 9
Thread: Soft Water & Pool Question
    Dec 2011
    Scottsdale, AZ
    2
    I have a plaster pool, 10yrs old, want a soft water system installed. The pool would be fed automatically with soft water unless some major plumbing work was done so that it was't. Will this harm my pool? Anything I need to do special if I decide to have it fed by the soft water?
    30,000 gunnite with emerald bay pebble tec
    Pentair fns 60 square feet DE filter
    Whisperflow 0.75 hp pump
    30,419
    Re: Soft Water & Pool Question
    Welcome to the forum. Assuming you have an adequate soft water source, (a household water softener probably won't work) there is generally no harm in having softened water in a pool (up to a point).....usually only benefits.
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    We use our softened water to top off periodically during the summer months when mother nature isn't cooperating with rain. We are on a well system, so we try to minimize water use as much as possible, though. Our softener system (Hague brand) not only softens water, but removes most of the iron which is present in these parts. Since our softener serves our whole house, we use potassium salt, rather than plain old sodium. It's a bit more expensive per bag, but it works as well and allows us to safely use the softened water for house plants and other purposes. During the summer, our water usage does increase, which means we spend more on salt and have more frequent regeneration cycles for the softener. Luckily, we have the softener discharge routed to septic (safe to do with potassium), which means that water is ultimately not wasted.
    We've had no problems through two seasons of use in our salt-water pool.
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
    There shouldn't be any problem. You do need to keep an eye on the CH level when using softened water. Since you live in AZ, where CH levels are usually quite high, it is unlikely to come up, but if the CH level gets too low you will need to add some calcium manually.
    Dec 2011
    Scottsdale, AZ
    2
    it will be a whole house soft water system. I have an option here, run the hard water line to the backyard and tap into the auto refill. Guess I should also have the plumber install a spigot for refills.
    Just dont see how I can do this if everything is soft water minus the auto refill, the pool will never fill up if I ever need to drain it and I am told here in AZ every 3-4 years thats a must.
    What would you guys do?
    Feb 2011
    Petaluma, Ca
    665
    For a plaster pool doesn't water need ch at least in the 300's? I just had the experience of getting a negative csi when my ch was lowered to 290 by the addition of rain water. I realize the ta & ph play a role in this.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    30,419
    I would like to change my less than adequate response.
    If your pool is already full and has a high calcium content, then the softened refill line would be of great benefit to reduce the calcium level and you whole house softener would almost surely handle that load.
    If your pool needs refilling, now or ever, the softener could NEVER keep up and you would have to run straight water through it without recharging it. I don't know if that has any effect on the long-term performance of the softener or not.
    Anyway, the whole idea is to control calcium and keep it around 250-400. The softener may very well help you do that.
    Filling the pool with water direct from the tap (no softener) and then using softened water for topping off when replacing evaporation is a good way to go. Depending on just how high your tap water CH levels are, you might even want to fill the pool with a mixture of direct and softened water.
    Aug 2011
    Gainesville, fl
    53
    Not sure who you are going with but I used to install Rainsoft systems. We always had to put a bypass in just incase something happened to the system. I also would try and place a spigot on both sides of the system. You could always ask to have this done. Hope this helps.
    12"x33" Summer Escapes AG Ring Quick set 1590 Gallons (Gift for my son by Grand-parents)
    Intex Krystal Clear Model 633 2500 GPH "B" Cartridge
