Thread: Hi I am Time-Man
    Hi I am Time-Man
    Another guy from sunny south africa checking in . Been searching for a pool forum for a while and glad to have found you guys . I am not in the industry but a DIY type of person , and as always before i start a project i try and find as much info on a subject as possible .
    Well some info : i bought a house with a broken pool a couple years back , and now decided to jump into the deep end and fix it myself !! The pool was a semi built up pool and who ever built it decided not to include any reinforcing into the structure !Iit is a massive pool 180 000 litres and not sunk into the ground 100% ,needless to say it broke it's back with the weight of the water , then they decided that a quick fix would be to fibreglass the pool to close the cracks . LOL that didn't work well and it just cracked right around again . Well i got a couple so called "pool builders" in to quote me and they must think i am daft and therefore i decided to do it myself .
    So please keep a eye out for my posts in the construction thread as i will post photo's and ask anyone to throw in advice where possible .
    Thank you before hand
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Hi I am Time-Man
    Sounds like you have quite a task ahead of you. It may pay to have an engineer have a look at the situation and make reccomendations as to what should be done to prevent more problems.
    Can you post pics?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Hi Lershac
    Yup as promised i just finished posting in the construction thread .
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
