Thread: Daily FC loss
    Mar 2012
    Suffolk, Va
    12
    Daily FC loss
    I'm new to the site and just started using the methods i have learned from pool school. everything so far is turning out great, exactly as it should in accordance with posts i have read on the site. My only question is: What is normal daily FC loss? I have performed the overnight FC loss test and my FC does not drop at all at night, but during the day i loose 3ppm a day (i'm guessing due to sunlight). this results in me having to add approx. a gallon and a half of 6% bleach every other day. is this normal chlorine consumption?
    FC - 7ppm
    PH - 7.4
    TA - 110
    CYA - 35ppm
    CH - 80ppm
    vinyl
    18000 gal.
    18, 000 gal.
    Inground, Vinyl lined
    300# Sand Filter
    1 HP Hayward pump
    Pool Pilot Digital SWG
    Re: Daily FC loss
    Welcome to TFP!
    3 ppm per day is on the high side, but isn't really surprising, give your CYA level, at least if your water is warm enough to swim in and your pool gets lots of sunlight. I recommend raising your CYA level to around 50. That should help reduce the amount of chlorine you need to use each day.
    Normal chlorine usage each day is typically around 2 ppm or a little less. However, this varies with the water temperature, amount of sunlight, and CYA level.
    Mar 2012
    Suffolk, Va
    12
    Re: Daily FC loss
    that's what worries me. right now daytime temps are just getting into the upper 70's and water temp is at 70. once the water temp starts to get up i'm worried that my FC loss is going to start getting even worse.
    18, 000 gal.
    300# Sand Filter
    1 HP Hayward pump
    30,414
    Re: Daily FC loss
    Stop worrying. Two things consume your FC. UV from the sun (which you reduce by increasing your CYA to 50) and organics in the pool (which you kill by adding more chlorine)
    Once you minimize your FC loss to UV, keeping adequate FC in the pool to get rid of organics is your only issue and your pool will then consume about the same as everyone's...depending on the variables.
    3ppm daily loss is not outrageous but I would up the CYA right away and see what that brings.
    22,544
    Re: Daily FC loss
    Just to reinforce what the others have said. I lost between 3 and 4 ppm per day until I got my CYA between 50 and 60. Then it dropped to about 2 ppm per day here in sunny south Alabama. I can tell when my CYA gets below 50 because I start having to use more bleach.
    Mar 2012
    Suffolk, Va
    12
    Re: Daily FC loss
    O.K. thanks for the info. i do have some cya dissolving in the skimmer sock, just waiting for it to finish disolving. i'll see how it does then.
    18, 000 gal.
    300# Sand Filter
    1 HP Hayward pump
