Results 1 to 8 of 8
Thread: Pump sizing and selection - 16k gal AGP
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    What would be the right size pump for a 16k gal AGP? The old pump is making a horrid whining/grinding noise and there is water trickling out of where the shaft enters the wet side.
    Does anyone have any recommendations on inexpensive but still reliable brands/models? (Seems like the Pentair Dynamo is pretty cheap.)
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Pump sizing and selection - 16k gal AGP
    Also would it be a good idea to get a 2-speed pump if I'm going to be running a SWG?
    Oct 2007
    Cedar Hill, TN
    252
    I'm looking for a pump right now, too.
    2 speed is what I'm going for. Running on low for circulation, high for cleaning only. Less energy, lower electricity bills!!
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    mas985's Avatar
    Pleasanton, CA
    11,742
    The smallest 2-speed pump you can find is big enough. I think the Dynamo comes in a 3/4 HP two speed.
    Mark
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Everywhere I look the 3/4hp 2-speed is at least $30 more expensive than the 1hp. Is this normal?
    Quote Originally Posted by mas985
    mas985's Avatar
    Pleasanton, CA
    11,742
    The 3/4 HP two speed should be less than the 1 HP as shown here:
    http://www.inyopools.com/pumps_aboveground_pentair.aspx
    http://www.poolplaza.com/C-Dynamo.html
    Mark
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I'll check that out... I was looking at:
    http://www.amazon.com/Pentair-340204-St ... B002FQIYH8
    mas985's Avatar
    Pleasanton, CA
    11,742
    The two pumps come from two different vendors so that is not surprising.
    Mark
