Equipment / Timer Problem
pd417
Jan 24, 2012
17
Recently completed install of our IGP. All Jandy equipment.
We have the Jandy Aqualink PS8 with the PDA.
Everything worked fine for the first couple weeks, then recently the pump and
filter wouldn't come on or go off at the preset times, I'd have to turn
everything on/off manually.
I checked the timer settings and everything is correct.
Any ideas as to why this is happening?
When your turning off manually are you using the PDA or breakers.. If your shutting off by breakers you might have a relay bad. If your shutting off by PDA I would do a master reset 3 times to make sure there isn't any ghosting... If that doesn't solve it the board might be bad... Since the unit us new call Jandy to warranty all parts and labor..
