Thread: Repairing A Hayward spider gasket
    Mar 2012
    Maryland
    87
    So my Hayward was acting funny. It was draining as well as filtering. I lost water by the next day. I ordered a new gasket online. However, I did some investigation to see what was wrong with the old gasket. I think many people (like myself) assume the gasket must be bad and must be replaced. Quite often the gasket adhesive separates from the base and it needs to be re-glued down. I removed the old gasket and inspected it for tears and cuts (a little worn but not bad). I removed the old adhesive and dried out the groove. I applied RTV (automotive RTV) to the groove and temporary assembled the head so it can press down on the gasket (squeezing the excess out). I waited 24 hours, opened it up and removed the excess and reassembled it. No leaks at all. It's been running for a few days now.
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Repairing A Hayward spider gasket
    adhesive usually isn't necessary, I find it can make getting a proper seal in the future difficult as you have to spend 30 minutes trying to get every bit of brittle rubber left behind stuck with glue. I'm glad it worked for you. Hayward has since switched from spider gaskets to a plate with a permanent gasket attached to it.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2012
    Maryland
    87
    Quote Originally Posted by X-PertPool
    I noticed this? It makes it more expensive to change.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Yeah it does, but they also seem to last longer. People often mess up their filters gaskets (even if they are new) by moving the handle while the pump is running. This unseats the gasket partially and then it gets warped out of place. Since the new way is permanently attached it makes it more resistant to this type of damage. Regardless They are both easy fixes, I kinda like the new system.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
