Results 1 to 10 of 10
Thread: Should I get bottom drain in AGP pool
    Hello everyone im in the process of buying a 18 by 54 pool with 1.5 hp 2 speed filter,I have not had a pool in over 10yrs and this bottom drain in agp is new to me and two are required,so my question is should i get them put in do the pros out weigh the cons I've heard, also the pool is being installed by pool store installers
    Pescador
    Re: Should I get bottom drain in AGP pool
    There are pros and cons. Each additional hole in the liner is an additional place where the pool could leak, though that isn't all that likely it is a small additional risk. Main drains can also be difficult to winterize properly in an above ground pool, which of course only matters if you live somewhere that has hard freezes. On the other hand, having a main drain can be very nice.
    Oct 2011
    New Caney, Texas
    414
    Welcome pescador!
    Be sure to spend some time in Pool School and you will need a good test kit (both in my sig below) once the pool is up.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Thanks Jasonlion I live in Chicago. also Thank you George I will check the out pool school
    Pescador
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Personally, for an 18' AGP I wouldn't get a main drain, I'd be concerned with potential leak, plus it would get in the way for swimmers, plus regular maintenance will eliminate the need.
    Just my 2 cents, keep it simple.
    Laenini's Avatar
    Aug 2008
    Brooklyn Center, MN
    90
    We are moving can't take our AGP with us, so I bought a new one the other day for the new house. When talking to the installer I brought up the question of including a main drain. He said he's never seen one in a AGP up here in Minnesota and he wouldn't want me to be the first one he learned on. That alone convinced me so I let the matter drop. But I do still have some mixed feelings. It seems to me that the people here who have them are glad they do, and I don't remember seeing anyone post that they severely regretted installing one. I admit though there is a whole winter's full of posts that I am behind on reading. I guess I would like to hear the stories from people who have one and totally regret it, if there is anyone who fits that description?
    Leanne
    Pool: 24' round by 48" deep AGP
    Waterway 1HP-2 speed pump, H100 Heater, sand filter, skimmer, using BBB (love it!)
    Hot tub: 2008 CalSpas, 8x8, 8 seats, 60+ jets, ozonator
    3 step bromine sanitation
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Laenini
    Hey fellow Minnesotan
    I would guess it is a very small percentage of agp pool owners that have a main drain. I would guess that percentage gets quite a bit smaller up here in the north. Personally, I wouldn't try it, like JasonLion and Cramer said, you will then have to winterize that line. I have yet to feel the need for it, and I have a deep end. Just curious, why is it interesting to you?
    Nov 2011
    Moberly,MO
    1,010
    As a builder I won't put a main drain in an abg. It is too big a risk for me, afraid it wouldn't be winterized correctly. And losing all the water out of it, then having to give a liner and labor to fix it all, plus the chance of a bad reputation not worth it in my book. If Wilbar wanted main drains in their abgs they would put them in the box when they package them.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    I have one, I love it!! You want to be set up correctly, and def need it installed to code and with all the necc shut offs ect.
    I'll never own a pool without main drains. I have far less cleanup in the pool and more time to swim.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    Thank you pool-creetin, any more AGP with drain owners who would like to share their stories positive or negative? I appreciate all the comments given so far
    Pescador
