Thread: Started using Insta-LINK Service Pro
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    It's really good.
    They don't mind cya of 80 but their fc limit is 4. I can work with that but probably for swg's will target cya of 60 to be on the safe side.
    What are your thoughts?
    also running numbers with temp from 70-104f with The Pool Calculator App . CH of 300 and TA of 80 seems all round good to target.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Started using Insta-LINK Service Pro
    cya is good between 40 and 100. my only concern is your TA should be between 100 and 120 every thing eles looks good
    poolsupplysales, you should read the recommended levels chart in Pool School! We recommend TA between 60 and 80 with a SWG and between 70 and 90 without. Only people who are using trichlor tablets should be running with TA as high as you recommend, and of course we don't recommend using trichlor.
