Bama Rambler said:WFDS-3 & WFDS-24 are the exact same pumps just rated differently. The WFDS-4 & WFDS-26 are the same as well.
Either of those will work fine. I'd go with the one that's readily available and less expensive.
Either the Quad 80 or 100 will be more than adequate for your pool. I agree that more filter is better and of the cost is close I'd probably go for the 100 as well.
Thanks for the quick reply Bama, I appreciate you chiming in!
1) Question for ya, on pentair's site they have the flow chart...Curve A,F for the wfds 3 and 24, Curve B, G for wfds 4 and 26...Am I correct the smaller curve (a/b) is for the low speed and larger curve *f, g) is for high speed? I'm trying to read the chart and if my reading is correct it would seem like low speed wouldnt move much water based on my piping info listed earlier in the forum.
2) the difference in price online between the filters is about 60 bucks so i think ill go for the 100. Have you heard of a1poolsupply.com or backyard pool superstore?
3) I'm going to need a new multiport correct? can you recommend one or point me in the right direction?
4) Are the unions on these pieces of equipment standard sizing that i can pick up at a plumbing store or home depot in case i would need to replace something or are they specialty pieces available from only pentair?
thanks again!
