Thread: savi lights
    Feb 2012
    central pa
    7
    savi lights
    i have a savi melody light system controlled by an intermatic remote control switch...of the three lights, one will not synch with the others....the lights come on and off fine, and worked at first, but somehow one of the lights got out of synch with the others....there is a waterfall controlled by the intermatic rc, which works...i can't find any info on this...anybody?
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Re: savi lights
    If you have not already tried to do this...Turn your lights off then back on. If the one light still is not syncing with the other then you have a problem with the light. With the way the savi is made it cant be fixed, just completely replaced. Hope this helps
    Feb 2012
    central pa
    7
    Re: savi lights
    thanks....still under warranty so i guess i'm good
    Tigershark QC Robot
