Thread: SWCG Chlorine Balance Question
    Aug 2010
    Dallas, TX
    4,052
    So I thought I saw this answered before, but couldn't find and and can't remember the answer if I did read it...
    When I have CYA of 80 in my salt pool, why does poolcalculator still recommend only 3ppm of FC? That makes me a bit nervous! I'm keeping it at 6 right now, but would not mind lowering if it is safe.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: SWCG Chlorine Balance Question
    The superchlorination that occurs in the cell makes up for the reduced activity of the chlorine in the water at the higher CYA.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by RobbieH
    With a CYA of 80 it recommends 4 ppm FC, not 3. It is consistent with the Chlorine / CYA Chart for SWG pools.
