Thread: too much sand in sand filter?
    My pressure seems high. I think I put too much sand in which could be increasing the pressure. How many inches above the laterals should the sand be?
    22,553
    Re: too much sand in sand filter?
    Whoa, Welcome to TFP first!
    That's not nearly enough info for us to make an informed guess. We need to know what the pressure is, does the gauge go to zero when the pump is off, what filter you have, what other equipment you have and what you're water looks like.
    Normal freeboard for a sand filter is about a foot from the top. That's the space where there's no sand.
    Having said that it's be very hard to add enough sand to the filter to make the pressure increase. I suspect it's something else.
    Welcome to TFP!
    Just to add to what Bama said, the normal problem with adding too much sand to a sand filter is that sand comes out when you backwash. Filtering is not normally affected by extra sand.
    Is your system brand new? Or do you know what your normal/clean filter pressure was before you replaced the sand?
    Thanks for the reply. After a backwash it sit at 16lbs but I just looked at the gauge with the pump off and is at 2 lbs. I think that's the problem.
    22,553
    You may have just found the issue. If the gauge doesn't go to zero then you can't trust it at any reading. I'd start by replacing it and see if that's the problem.
