Results 1 to 9 of 9
Thread: Another newb from Texas
    Hello. I've been lurking here for a long time - excellent source of information - and have learned a lot. My water got horrible cloudy green while setting up my 6300 gallon 18' Intex above-ground pool this year. I added water slowly, making darn sure everything was straight because some of the poles slipped off of the concrete blocks last year. I also built a deck and PVC ladder, & added a skimmer. The water was so bad, and then my salt-water generator died, so I've been taking advice from the experts here, got a test kit & a ton of bleach, and it's slowly getting better. Pics of the pool are below. I put in a concrete pad around the corner (and out of site) for my 2650 gph sand pump. I also plan to add a "rainbow" water fall, but haven't gotten there yet. Been shocking the pool for the last few days.
    Anyway, Howdy from Texas!
    -Mark
    Old cartridge filter and new sand pump. This is where the saltwater generator will go when Intex ships me the warranty replacement.
    Skimmer basket & main drain, each with a PVC ball valve. The plan is to use the main drain for vacuuming.
    The ladder is done, but I've got a big piece of wood on it temporarily to keep the kids out. I still need to figure out an easier way to "close" the pool so curious toddlers don't drown. My puppy did a good job posing for the picture. You can also see my make-shift pool brush, which is a big piece of PVC, a swivel mop, and a couple of tie-straps.
    No pool right now: hoping for a gunite pool in the near future
    Previous pool (poles rusted out due to salt water):
    6300 gallon Intex above-ground pool
    2650 GPH Intex 100lb sand filter
    CS8110 Salt-water Generator
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Another newb from Texas
    Hey Mark
    You know we always have room for one more Texan
    Glad to have you!
    You're done SLAMing when:
    Feb 2012
    Phoenix, AZ
    728
    Welcome to TFP Mark!
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, LS1M
    That is a nice intex setup you have there! Are those filled concrete blocks for the frame? What do you have on the inside of them under the pool?
    Thanks! I put a lot of work into making that pool easy to use & maintain.
    To level the pool I set the concrete blocks in a circle and drilled holes between them with a 1" hammer drill. Adjacent blocks have a piece of 5/8" rebar inserted (to keep them connected). I dug out the ground on the "high" side of the yard to level the blocks. Used a string-level to get it right. Didn't work out perfect, but I'm within an inch or so. First I filled each block with concrete, let that dry, then I filled the interior with sharp sand (not masonry sand - sharp sand is used in concrete-making, and it hasn't been smoothed-out for masonry and/or sandbox use. It does a much better job of staying put ) Like I said, not perfect, but I couldn't figure out a better way to get it secure & level. Seems to work pretty well... I got the sand real wet then spread out the pool.
    Can't wait to get the )(@#$(!!@#@)!!! algae out & clear the water. I've been shocking it with bleach for a week! But I think I'm getting closer...
    -Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Hey Mark,
    Sounds like a bomb proof install!
    If we can be of any help with the shocking let us know. We love test numbers and pictures
    Funny you should mention bomb proof. You should look at my storm shelter design:
    http://www.ls1m.com
    I evacuated during Rita - 36 hours on the freeway - and I vowed to never, ever, ever leave again. Here on the gulf coast, we see a big honker hurricane evry few years. But that traffic jam was epic!
    I've got a thread on clearing up my pool water:
    is-this-normal-t41238.html
    I've been shocking it for about a week now. It's still not clear! Unblieveable. My CYA is at 40, and according to the pool calculator, I need a FC level of 16 or so. I have it at 23 now, and it drops down to 17 or so after 12 hours, so I crank it up again. I just backflushed my filter again. I've been told to be patient, but it's not easy! It's a cloudy blue instead of green, at least.
    Today FedEx brought me a brand-new (warranty) salt-water generator, an Entex CS8110. I'm not going to hook it up until my chemistry is just right, though. I'm using bleach to clear the water, and I may get some Diatometrius Earth & add it to the filter if it doesn't clear up soon...
    woohoo's Avatar
    Feb 2012
    Collierville, TN
    33
    Welcome to TFP!
    Cloudy blue is half way to clear! I am on the tail end of an epic swamp to clear journey myself. DE added to the sand filter helped but patience was (and is) still needed. Remember to run your pool sample water through a coffee filter and get to room temp when testing for CYA. Results can otherwise be unreliable with a cloudy pool. Good luck!
    33,000 Gallon Vinyl Liner In-Ground Pool
    Intelliflo VS Pump; Triton II TR100 Sand Filter with Plumbed Waste Line
    IC40 SWG Cell; Easy Touch 4 Control Panel; Polaris PB4-60Q Halcyon Booster Pump
    Polaris 280 Automatic Cleaner; Dedicated return line; 1/2 Full Beer, Something on the Weber;
    AND, most importantly a TF100 Test Kit and a SpeedStir.
