Results 1 to 12 of 12
Thread: Jandy Deck Jets -- distance to water edge
    I wondered how far from the water edge a deck jet can be placed. Our PB suggested 3 feet max but I think the kids will undoubtedly be playing in the deck jet water and I really didn't want to put it so close to water edge.
    Jet's and main drain/returns will all be on a 2 speed Jandy pump. My thought was about 5-6 feet from water edge.
    Obviously we'll have to adjust flow rates to jets to reach water but wanted to see what others suggest. Also do you think 6 jets would be too noisy?
    Thanks.
    Charlotte, North Carolina, 30k, in-ground concrete (built 2001, remodeled 4/2012), PebbleSheen Blue Aqua, Polaris 360, Jandy 1.0 HP Dual Speed Stealth Pump, Stenner Pump 45MHP2 220v - 1/4" black tubing mounted on 15 gallon UV Gray tank, Jandy CV340 CF, CMP deck jets x6. TF-100.
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Re: Jandy Deck Jets -- distance to water edge
    I currently have my jets about 6' away from the edge, 3' pool deck walkway and 3' planter where the jets are along the fence. I can also speed up my pump and they will shoot over the pool and hit the house about 30' away. I have them set where the stream is in the middle of the pool and it does make some noise, but I like the sound of running water. I should also say I don't have the Jandy deck Jets but I have the same parts they use.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Dec 2010
    San Diego, CA
    1,137
    Quote Originally Posted by SCCS
    Where did you get the parts and can you post pics of how you hooked them up along the fence? I'm thinking of doing something similar myself.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Feb 2012
    Phoenix, AZ
    728
    Hey gujjuman, welcome to TFP! I would assume that 5-6 feet will be just fine..but it will depend on a few things...
    What is the HP of your pump? Is your plumbing 1.5" or 2"? Are you going to have any other water features? And what is the distance from your pump to the jets? All of these will be factors in deck jet pressure.
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    You can view the product line here. I used the 1/2" products for my install. I ordered them through "Grainger.com". I tapped into the 2" outlet line from the filter and installed a electric valve. I used 2" pvc for the run and installed 2"slip x 2"slip x 1/2" thread tee's which the jet is screwed onto at each location. All I have to do is push a button on my Easytouch system and the pump's speed is readjusted and the valves open's. I posted a few pictures here.
    Dec 2010
    San Diego, CA
    1,137
    Thanks. Do you remember which nozzle you used?
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Sorry gujjuman but I am not try to hijack this thread.
    Carlscan 26 I use the 3/8" nozzles. I started out using the 1/4" nozzles but that didn't produce enough flow for the swg to work. So I changed to the 3/8" nozzles and things work great.
    Jun 2011
    Greenwood, SC
    23
    Mine are 22" from the edge of the pool
    24K gal ( pool,spa,basin)
    Pentair Sand Filter, IG Plaster/ Inifinity Edge - Diamond Brite Onyx
    (2) Sta-Rite 2HP, Pentair 400K BTU heater
    Jandy Aquapure SWG w/ AquaLink, Tiger Shark Robot
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hello~
    We don't have children, but we've had many children of all ages in our pool over the years. They have always preferred to be IN the pool while enjoying the jets or the arcing waterfall; no one has ever wanted to play on the deck in the deck jets. Thinking about it, I believe that this would be unpleasant; the water is under quite a bit of pressure. Our Jandy jets are not the same as the playtime water fountains and such found in public playgrounds.
    Yes, the deck jets are noisy. I am conscious of disturbing the neighbors and don't run them at night. If we want a water feature on while swimming at night, we run the sheer waterfall, which makes much less noise, but can be run all night if we are trying to boost pH after adjusting the TA down.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Thanks for all the replies.
    We will have a Jandy Stealth 1.0-2 speed pump. Cartridge Filter and peristaltic pump (no other water features, spa, falls, etc). The plumbing is all 2" which splits to 3/4" for the deck jets. They are pretty far from the pump itself, the first set of 3 will be about 50 feet and the others probably around 120 feet.
    I didn't realize the jets would be painful for the kids. I fully expected them to be running around in the water. Is that most people's experience?
    SCCS--no worries.
    My kids and their visitors often play with the deck jets. Mine are about 18" from the pool edge and shoot about 10' into the pool. The water pressure is not great and significantly less than a typical garden hose.
    22K 18x36 in ground concrete pool. Intelliflo VF, Hayward cartridge filter, Zodiac Tri salt chlorinator with pH control, Rola Chem oRP chlorine dosing. Polaris power stream and deck jets with separate Intelliflo VS. Heattseeker solar heating. Jandy Aqualink.
    I have 4 deck jets and each has it's own ball valve so we can adjust the pressure. So they can shoot from 1 foot to probably ~30 feet. Kids love them in and out of the water.
    20'x34' gunite pool, 7' raised spa, Wet Edge Primera, VS3050 pump, 2x whisperflo pump for water features and in-floor cleaner, CC520 Cartridge filter, Pentair 400k btu heater, Intellichlor IC40, Paramount PV3, Easytouch8
