Results 1 to 11 of 11
Thread: Do I need a heater in indiana?
    Hi, I live in NWI and just bought a 27' pool.
    Im wondering if I will need a heater.
    I can get a Rheem 260000 btu with the package for $1500.
    I dont mind colder water but I have a wife, 4yo daughter and 2 yo son
    that will most likely be using it more than me.
    we're about 30 miles south of Chicago and can get all four seasons in the same week.
    Will that heater be enough? Is it even worth the $1500?
    27' AGP, stenner pump, 30 gallon holding tank, 2hp two speed pump, cartridge filter, 12.5% liquid chlorine.
    Feb 2008
    Denton, TX
    5,061
    Re: Do I need a heater in indiana?
    If I were an Indiana resident, I would definitely have a way to heat the water. Even people in Texas have heaters.
    We're in SE Wisconsin just over the border with a 27 ft round above ground. We like the water around 88 and we're happy. We use 4 -2X20 solar panels and as long as the sun is out we're good. As the summer ends we do use the solar cover more frequently along with the panels. When you factor in the heater, the plumbing and the monthly cost that's when you will be able to decide if you need it.
    27 ft round 52" wall
    Cartridge filter
    Above Ground
    2 hp Hayward pump
    Using 2 2x20 solar panels
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You will spend a significant amount of money running that heater. Maybe several hundred a month.
    I'm just a little south of Bloomington and heat mine with solar. If you have the space, it is a good alternative. It won't let you swim in April or October, but it will make a 10 degree difference in your water pretty easily in the summer.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I too use solar...my theory/experience is that solar can add heat in the summer months , but when the season changes occur up here (Minnesota, and I would guess in Indiana too), they happen so fast that no heat source will extend the swim season much without costing an arm and a least 2 legs.
    SW Indiana
    9,199
    Quote Originally Posted by linen
    My experience as well. Even though I can keep the water at 85 or so, once the air temperature is down around 80, nobody wants to swim.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by JohnT
    In New England, if we only swam when the air temps were 80+, our swim season might be a 1.5 months!
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Definitely get a heater! I don't have any experience with solar, it sounds great but I want something that I can control anytime. Our heater is 100k btu (which we paid around $850 for).
    This year I might run it a bit more (while watching the gas meter) and try to swim early if it works out that way. It's excellent for bumping a few degrees if the weather is great but the water is only 80-85 in the morning. Or to make sure the temp doesn't drop too low overnight.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Speedo
    What you describe in that sentence is exactly what solar is great for, ours gets turned on when sun hits panels (about 10 am, due to shade) and by 2 pm, water is significantly warmer. Like was mentioned previously, solar is not great for extending a season (normally, but I have hopes this year), but it's great for bumping up temperature during the day due to loss at night. Cheap too Gas heaters in northern clims, can extend the season, but keep in mind the cost is high to do it. This may not be you, but some people tend to overuse them "cause they have it" even when the pool really doesn't need it (and then they complain about how much it costs ) .
    Last season I probably spent around $250-300 in gas costs. But I didn't extend my season by much it was mostly used on days where the water would otherwise be too cold but the weather was nice. Or if it's warm enough but cloudy. If I had the budget to do so I would definitely have both gas and solar
    Aaron
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    I was wondering about getting a heater for the pool as I found one on craigslist reasonably priced. My brother suggested I think twice due to the cost. I am glad I found this thread. Guess I won't get the heater. Would like to rig up some type of solar heater though.
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
