Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Is this skimmer weird...or am I? (Both I'm guessing).
    So I bought my house about a year ago - and just now have gotten around to addressing how it seems there is an object that should not be in the line that returns to my pump at the bottom of my skimmer. Before if ripped when I tried to pull it out it had a hayward v093c part number on it. A v093c actually does fit in the top cavity, if you put it in the v093c in UPSIDE DOWN!
    Has anyone seen this before? Can i just take a hacksaw blade and carefully cut thru this guy so I can remove it? It is keeping me from being able to vacuum because the hole is smaller than a male hose adapter.
    Please take pity on a father of 2 in his early 30's. And my birthday is tomorrow.
    Dec 2010
    San Diego, CA
    1,137
    Re: Is this skimmer weird...or am I? (Both I'm guessing).
    Happy birthday and welcome to the forum!
    Someone will be along soon to answer your question
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Jul 2009
    London and France
    574
    If all is working then I would leave well alone. If you want to vacuum why can't you get an iris plate that attaches to the vac hose and sits above the skimmer basket?
    The thought did cross my mind. I guess I had 2 things bothering me about that...
    1. I forgot to mention the skimmer model - it's a hayward 1070. Looking at the specs it definitely seems the foreign object should not be there. I'm concerned about some minimal flow dampening and deterioration of this thing clogging/damaging my equipment(it was already chipped in a few places).
    2. Looking at the plates it seems the minimum water level in my pool would need to be higher to use a plate vs. placing the hose directly into the skimmer plumbing. I live in sarasota, fl. The water drops in the winter - but I try not to waste water and add because in the spring and summer the rains replenish the lost water. That being said I would like to vacuum in the winter time when the water level is a little lower.
    Oh - and I don't want to spend money if I don't have to.
    Columbus Ohio
    178
    I dont have the same skimmer but I do have a Hayward with the same thing. My pool builder capped it from underneath and I would say if yours is capped on the top side, it wont be plummed into your system... I would leave it the way it is...
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    hmmmm....maybe this picture isn't that great.
    The hole on the right IS capped from underneath.
    The left one isn't capped - it goes back to the pump.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am not familiar with your skimmer, but that piece looks to be a rubber collar, maybe for sealing to the vacuum line of a cleaner? I would remove it if comes out easily during normal pool operation.
    See - that's what I think - but I can't find a hose that fits in it.
    I tried taking it out, but it seems to be partially jammed/wedged against the lip of the skimmer bottom - that's why i was thinking of trying to *carefully* cut it top to bottom on both sides and pull it out.
    22,542
    That piece should come out of there. Id' try prying it first then you could carefully cut a couple of notches in it if you have to. Be real careful not to cut into the pipe in the bottom of the skimmer.
    Dec 2010
    San Diego, CA
    1,137
    Quote Originally Posted by theneworchards
    The hole on the right has that collar thing. The one on the left I can't make out what's in it - I think dirt and this is the one that is capped? It's the collar thing you want to remove right?
    22,542
    Unless your seeing them mirrored form me, the one on the left has the collar thing in it.
    Dec 2010
    San Diego, CA
    1,137
    Weirdness - for me the opening with the ripped collar is on the right for me...
    22,542
    Weirdness indeed! At any rate, the collar whether it's on the right or left should come out! Out darn collar!! Out I say!!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Left for me, I think carlscan is dreaming.
    Out, *@mned collar, out, I say!
    Dec 2010
    San Diego, CA
    1,137
    It's the browser on my iPad - using IE on windows box it is on the left. Pics in other threads are fine...but then in the http://www.troublefreepool.com/cartr...ly-t41312.html thread the 'screen and debris.jpg' is upside down on the iPad but the 'Equipment.jpg' is fine.
    Weird. Very weird.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    ahhh...Ipad...there's the problem
    OK - thanks guys for all the help. I think I will remove it then...
    I'll let you all know how it goes....hopefully not with more questions!
    Alright -
    Thanks to all for helping me follow my instincts to remove this stupid collar. It was super tedious, but now i can put the appropriate collar in there (which so happens to be the same hayward part # but completely different dimensionally (???)).
    Anywhoo, all is well and I am super pysched and grateful!
  20. Back To Top    #20
    Dec 2010
    San Diego, CA
    1,137
    Nice job!
