Thread: How do I lower the water level of my pool? (valve pics!)
    We've had heavy rains and I'd like to lower the water level in my pool.
    Besides siphoning it, or relying on an external pump, can you advise how I could lower the water level a few inches? There are exhaustive pix of my equipment pad, as well as some solid analysis of what each valve does, by jblauert at this link: filter-pump-spagetti-is-my-spa-doomed-to-heat-the-pool-t41153.html
    I only want to lower the level of water in the pool, not to empty it!
    60k gallon (est), 83ft PebbleTech pool, spa. Goldline Aqualogic controller, AQL-PS-8. 2 Hayward SwimClear C5025 filters. Hayward H400ED2 heater. 2 T-15 SWG. Pool pump: Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor. Spa pump: Hayward SP4015NS pump / 1.0 HP Emerson 1081 motor (SF 1.4, RPM 3450, Amps SF 6.2-5.8/11.6). Hayward 5060 3/4HP booster pump. 6' x 9' waterfall driven by a Hayward SP4015NS pump (115 GPM @ 47' of head & 2200 watts). Spa jets driven by a Hayward SP4015NS pump / 1.5 HP A.O Smith SP1615-Z-1-BNC motor (SF 1.6, RPM 3450, Amps SF 11.0 - 10.2/20.4) Still learning!
    38,284
    Re: How do I lower the water level of my pool? (valve pics!)
    You know looking at these pix again for a different reason this time ... I do not see a valve on your filter at all.
    How do you clean the filter? It does not appear that you have the ability to backwash.
    I have a multivalve on my DE filter that allows me to pump to waste which is what you are looking to do, but I do not even see the simple slider valve on the filter that would allow you to backwash ... or are those not DE fliters.
    In any case I found your solution:
    Right out of the pump it looks like there is a hose bib. Hook a hose to it and open it up, that will remove water (with the pump on) ... make sure you do not pump it down below the skimmers.
    Thanks once again, jblauert. This is working!
    Trying to answer your question... I would not list pool care among my competencies. But my understanding is that these are cartridge filters, not sand or DE filters. To wash them you open them up and hose them out -- I don't think backwashing is done. Somebody more knowledgeable can surely correct me if I'm wrong on this.
    38,284
    They all look similar from the outside ... your looks a lot like my DE filter, but you are correct if it is a cartridge, you just pull them out and spray them down.
