Thread: Can I do this?
    Apr 2011
    Lynchburg VA
    393
    Can I do this?
    I need to add CYA to my pool. I am familiar with the hanging the sock in front of the return jet method but I have an old inline chlorine dispenser that I used back in the day that I use to fill with those evil 3" pucks.....can I put the CYA in that to dissolve?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Can I do this?
    ...I'm not sure, but why? I prefer the dump-it-in-the-skimmer method, and just don't backwash for a week or so. Even the sock is too much work for me
    Apr 2011
    Lynchburg VA
    393
    Re: Can I do this?
    It just seems like the perfect device for dissolving the CYA......as long as it doesn't exploded due to some crazy chemical reaction!
    Pool School
    Pool Calculator
    Test Kits
    South Central NJ
    3,192
    Re: Can I do this?
    Not a recommended procedure. A chlorinator is designed to hold tabs only. Putting powders in it will cause a washout effect inside allowing undissolved CYA powder to pass. I doubt that it would explode like if you mixed chlorine types but is a bad idea, none the less, IMHO.
    Scott
    Owner of - PoolGuyNJ LLC
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Can I do this?
    I take a knee high,,,,,,,,,fill it up..........loosely tie a knot............and chunk it in the skimmer to dissolve. It don't take long! Just don't backwash too soon.
    Apr 2011
    Lynchburg VA
    393
    Re: Can I do this?
    Thanks for the feedback, a knee high it is.
    Pool School
    Pool Calculator
    Test Kits
