Thread: How to clear a clogged skimmer suction line?
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    I have 2 surface skimmers and one is clogged with acorns/leaves I think.
    When I close the other 2 lines (one is in bottom drain) a little water spurts into the pump basket.
    I made a garden hose threaded pvc adaptor to pump it from the skimmer end but no relief.
    Any suggestions?
    I don't think drain snakes would help as the fittings are probably 90 degrees - this is the farthest skimmer on the opposite side of the pool.
    Has anyone used a cobra drain cleaner (hose attachment that swells to seal) from the pump end of a line?
    10,000 Gal. Inground Plaster Lap Pool
    Sand Filter
    New Orleans, LA
    Dec 2010
    San Diego, CA
    1,137
    Re: How to clear a clogged skimmer suction line?
    The Cobras and Drain Kings have had some success on the forum. You want to push the water back to the source of the blockage rather than pushing the blockage further in.
    Another technique which is more about volume than pressure is to take a wet towel and push a hose into the pipe and wrap the space around the opening and pipe with the towel to seal up the opening as best as possible. Turn on full blast and see if you can't flush the debris out that way too.
    You *can* get a thin snake through 90 degree bends. But you want that to be a last resort as PVC is soft and you could damage it snaking it out.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    30,413
    I have no personal experience but several here on the forum have used them....generally with good results if the clog is not too tight.
    Others here have suggested inserting the garden hose into the skimmer line at the pump and then wrapping or packing cloth tightly around it to for a good seal and then turning on the water. If it's an easy clog, that might get it and save some money.
    Carlscan beat me to it.....I swear I didn't copy his post!!
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    Thanks!....Boy, y'all are fast on this board!
    Sand Filter
    New Orleans, LA
    Mar 2007
    Coastalish 'down easter'
    4,160
    Their spouses HATE it
    Luv& Luk
    -Ted
