Results 1 to 7 of 7
Thread: Pump Leaking
    Mar 2012
    Australia
    18
    Pump Leaking
    I noticed this today as one of the pumps is leaking and quite alot of water is coming out when the filter is on. When I turn it off, I can hear a high suction noise which then goes. Hopefully it isn't too serious to fix
    Although a little hard to see, I took a picture while the filter was running. Above where the yellow logo is, you can see the water over flowing.
    Cheers,
    Feb 2008
    Denton, TX
    5,061
    Re: Pump Leaking
    I can't really tell where the water is coming out from the picture. Just to confirm, is your strainer basket o ring lubed and is the lid on tight?
    Mar 2012
    Australia
    18
    Re: Pump Leaking
    Yup. I double checked to make sure and all is secure. Here's where the water continually flows out from:
    Thankyou for your time on this.
    38,262
    Re: Pump Leaking
    That is a black union fitting that screws onto the pump right? If so, there should be an o-ring between it and the pump creating the seal. Maybe it is cracked. Can you loosen the 2 fittings that attach to the pump, move the pump/motor and check the o-rings?
    Mar 2012
    Australia
    18
    Re: Pump Leaking
    I tried but it simply wouldn't budge. To be honest, I'm not too confident to start playing around with it either Maybe I'll get in the professionals.
    Feb 2008
    Denton, TX
    5,061
    Re: Pump Leaking
    If you are not comfortable messing with the connections, calling a pro in is a good idea.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pump Leaking
    You are leaking from that 1/2 union!
    Either the o-ring has gone bad or the union is broken or has backed off.
    I think this is something you can fix/ establish the cause of yourself. If you don't have a wrench that will allow you to tighten or loosen the union, you can use a belt (like you'd use to keep your pants up) as a 'strap wrench') to do the job.
    We can and will help you DIY this but, if this is out of your comfort level, by all means - call in the pool dudes (&watch what they do, so you can DIY next time
    Luv& Luk
    -Ted
