Results 1 to 8 of 8
Thread: Pool Calcium Hardness 90 ppm, tap water 150 ppm
    The pool's calcium hardness is 90 ppm.
    The hose bib connected to the auto-fill line gives me water with 150 ppm.
    How is this possible? Did I let my pH get to high and the water gave up some of it's calcium hardness?
    29K gallon rectangle, vinyl, Hayward Sand filter, Dolphin Nautilus robotic vacuum
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Pool Calcium Hardness 90 ppm, tap water 150 ppm
    It could be turning to scale.
    You could have had a lot of rainwater dilution
    The water company switched sources, so the fill water was much lower than it is now.
    Now it's time for me to repeat the TFP Mantra: Could you post a full set of test results?
    30,408
    Rainwater. (please don't tell us you live in Phoenix )
    38,260
    I don't think the tap water would only be 150 if they were in Phoenix
    Feb 2008
    Denton, TX
    5,061
    Richard has a good point. Calcium that has precipitated out of solution (as scale on pool surfaces) will not show up on your CH test. He also has another good point in that many municipalities use different water sources at different times of the year. Where I live, my tap water TA and CH vary widely throughout the year.
    It would be a good idea to see a full set of tests. I'm curious to know what a CSI might be for your pool.
    What I meant by "Did I let my pH get to high and the water gave up some of it's calcium hardness?" was that it might be leaving the water and sticking to the surfaces (scaling).
    Feb 2008
    Denton, TX
    5,061
    It is certainly plausible.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    The tap water may also come from different sources at different times of the year.
