Results 1 to 8 of 8
Thread: Pump timer question
    Smykowski's Avatar
    Sep 2011
    3,065
    Pump timer question
    I'm looking at a portable timer for my pumps, and I think this one will do it:
    http://www.google.com/products/catalog? ... CGgQ8wIwAQ
    Does anyone have this timer? If so what does the back look like (no pictures anywhere on the interwebs)? I want to make sure I can mount it to my current setup before I buy it.
    Thanks.
    Re: Pump timer question
    I dont know much bout that timer;i just purchased a intermatic T101 off of ebay for 25.00 dollars from shipping. You would have to mount it to board and install a plug nd electrical cord though.
    All of the Intermatic are fairly good. The style you linked to is reasonably good, but it won't last as long as a hard wired unit. Of course, a hard wired unit isn't practical in all situations.
    Smykowski's Avatar
    Sep 2011
    3,065
    I think I'm going to have to go hardwired. Apparently that timer is only suitable for 1HP motors, and mine are 1.5HP.
    It'll be a little more work, but not insurmountable. Thanks for looking guys.
    Quote Originally Posted by Smykowski
    That's what I was just wondering, the non-hardwired timers I've seen on Amazon are 15amp. I was pretty sure my 2HP pump is too much for it and I don't want the hassle of unplugging and re-plugging to run on high speed.
    Hardwired might be a bit above my skill set.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Smykowski's Avatar
    Sep 2011
    3,065
    I ended up using the timers from www.swimmingpooltimeswitch.com, they're rated for 40amps and seem to be a "generic" version of comparable Intermatic timers. Very simple to wire and I'll confirm that I did it all correctly in a few weeks when I open the pool and turn the pumps on.
    Biggest problem I had was getting the conduit and box all set up, mounted, and connected. The holes are not threaded like an off-the-shelf all-weather box, and they don't line up with "standard" boxes. I made it work, but it could've been easier.
    May 2009
    Youngsville NC
    395
    What timer did you get and how did you wire it ? is your pump only 120 V ?
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Smykowski's Avatar
    Sep 2011
    3,065
    http://www.swimmingpooltimeswitch.com/CD-104P.html
    CD101 worked for me. My pump plugs into a twist lock receptacle. Original owner had a plain 20amp switch in the circuit. I rearranged a little bit, and put the timer in the place of the switch.
