Thread: Looking for a 2 inch valve
    Dec 2007
    Central New York
    Somewhere in my internet travels, I ran across a 2 inch valve that had positive stops. I think 32 stops, but not sure. It was a 2 inch ball valve. The positive stops were so the valve wouldn't "creep" open or close. I thought I bookmarked it, but I've been looking all day and can't find it. I think it was an online pool store; but not sure. Does it ring-a-bell with anyone?
    Anyone have trouble with Jandy valves creeping open/closed?
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Re: Looking for a 2 inch valve
    Quote Originally Posted by Hotrod30
    Nope, which is why they are used in pool constrution more than ball valves.
    Pentair makes one. Check out the site below.
    "These valves are ideal for diverting, shuting-off, or mixing applications. The Teflon composite diverter seal requires no lubrication. Field-adjustable stops ensure precise positioning while simplifying use, and the extra-wide diverter offers superior sealing when used with valve actuators." ... 21&back=16
