Thread: Liquid heat and the likes
    May 2011
    Los Angeles, CA
    228
    Hello all!
    This season I am planning to install a solar cover with an automatic reel. While searching for the equipment, i stumbled upon liquid heat. It says that it is a chemical added to the pool everyday to retain heat and reduce evaporation.
    The main reason for a solar cover is to reduce evaporation. Do you guys think rather than installing a solar cover, I should use something like liquid heat?
    Any ideas will be most appreciated.
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Aug 2010
    Dallas, TX
    4,052
    Re: Liquid heat and the likes
    I have no idea what Liquid Heat is, but I try to avoid putting any chemicals in my pool it doesn't need.
    38,415
    There was just a big discussion about these recently. Basically if forms a layer on the water to prevent evap. Apparently does not work well if it is generally windy and if you use the pool alot then it gets splashed out of the pool.
    Let me see if I can find the link.
    Here it is.
