Results 1 to 9 of 9
Thread: most bang for the buck(chlorine)
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Didn't i see a break down of cost of different types of chlorination somewhere on here? What types had how much available chlorine etc. If so could someone please point me to it?
    Thanks
    36x18,MAYBE 27000gal?,VINYL.3/4 HP,PAC-FAB SUPER FLO SAND FILTER
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: most bang for the buck(chlorine)
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Yeah! Thats it.Thanks.I need to shock the bjesus out o my swamp and I need CYA so im thinking of going with pucks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by buzzbait00
    Pucks don't dissolve very fast.
    I see no problem with filling a floater with enough pucks to raise CYA, but you'll still need to add some bleach or Cal-hypo to raise the FC fast enough to get ahead of the algae. Bleach would be best, as it doesn't add any extra Calcium.
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Ok,thanks.
    Or, if you are low on CH, or not so high that it matters, you could consider cal-hypo. In the big buckets it is cheaper than bleach and you can shock the heck out of the pool really fast. I like to keep it on hand because it stores so well. When you need to shock, sometimes the amount of bleach you need can be a problem to get a hold of fast and at a good price. But if you have a pool store that has 12% bleach that may be even better overall.
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Yeah, im going with cal-hypo. My ch is low. I figure 1 lbs of cal-hypo = a big (182oz?) bottle of 6%. 1Lbs of cal-hypo costs me bout $3.24 and bleach has went way up round here. $3.00 a big bottle.... Thats up. 50 since last summer!!
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    The linked post by ChemGeek is a very interesting comparison of costs; but it is a four year old thread. Obviously prices have changed since then, but does 6% bleach still work out to be the most cost effective?
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    I use to find 6% on sale all the time for. 99 a regular bottle. Now its usually $1.79. At the local piggly wiggly they will only.sell me 4 bottles at a time because i might be making crystal meth with it that 1lb@$3.24 for cal-hypo is just the price at the closest place. Bet i could beat it if i looked around.
