Thread: Add superchlorine?
    Mar 2012
    Australia
    18
    Add superchlorine?
    This is embarrassing and may sound ridiculous, but I found a dead mouse floating in my pool, and lets just say my OCD isn't coping well with it. My pool is salt water and is perfect in terms of chemical balance. What would you do in this predicament?
    Feb 2008
    Denton, TX
    5,061
    Re: Add superchlorine?
    Scoop it out and throw it away. If your pool is properly sanitized, there should be nothing to worry about. If it isn't properly sanitized, then you should probably shock your pool.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Or, if your pool is properly sanitized, and it would make you feel better to shock it, then you should probably shock it.
