Thread: Getting ready
    Getting ready
    During the off season, the ony real maintenence I've done is to run pump/filter 3 hours daily and dump chlorine in about every two weeks just to keep algae at bay.
    Water temp has been 78f for about 3 weeks and I'm now working to dial everything into balance.
    I've super-chlorinated....swept and vacuumed and have been using TF100 kit to check chemistry.
    Everything seems to be fine except CYA is not getting a reading. I purchased an 8oz bottle of R-0013 reagent , midseason last summer. Could the reagent have gone bad in 6 months?
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    30,403
    Re: Getting ready
    Not very likely. It is pretty inert and, to my knowledge, we've had no reports of it going bad.
    What do you expect your CYA to be? When did you test for it and get a reading?
    It is not uncommon for CYA to disappear over the winter. Mine has done so twice but this winter it did not.
    Re: Getting ready
    I have tried to maintain 70ppm although towards the end of he season last year CYA began to drop. The reason for this is unknown to me.
    The funny thing is that the season before CYA was off the charts and I did two half pool drains and frefills at the beginning of last season.
    Now I am careful not to really on trichlor pucks for chlorination.
    We haven't had much rain so I'm not having pool water overflow and dilute.I do get evaporation and add water about once a month or so.
    30,403
    Re: Getting ready
    You certainly could get a second test done at a pool store to confirm you have zero. Not to rely upon their accuracy but to perhaps just to check for thepresence of CYA.
    Other members experiences would indicate it is more likely that your CYA is really zero.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Getting ready
    I would seriouly doubt this reagent went bad...especially in that time frame. I use turbidity reagents at work and they last a very long time.
    Essential Links:
    22,542
    Re: Getting ready
    You could always buy a bottle of standard solution and test your reagent but I also doubt it's bad.
