Thread: Proper Placement Of Return Jets
    Sep 2010
    Noblesville, IN
    104
    I put the jets on last spring and didn't pay much attention to the direction they were aimed. I was wondering is there a certain way they should aim? Down, up, ccw, cw?
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    Jan 2011
    Richmond, Texas
    595
    Re: Proper Placement Of Return Jets
    Not sure if it is the right way, but in my pool all returns point to the right making a clockwise flow through out the pool. It seems to work good.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    22,539
    You should adjust the eyeball(s) to give the best circulation in the pool whichever direction that happens to be. Mine is set to produce a counterclockwise circulation with the flow from the eyeball barely rippling the surface of the water. That gives me the best circulation and the best skimmer action.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Sep 2010
    Noblesville, IN
    104
    Thanks for the info.
    Mar 2010
    Quakertown, PA
    50
    The circulation direction should be away from the skimmer so that the water passes the skimmer then the return, that way the skimmer takes 'old' water. In my case that would be counterclockwise. I also draw my test water a bit to the left of the skimmer to take 'old' water.
    Arvil, 30ft round, 21k gal, AG/vinyl(2003), StaRiteIII hp cartridge 150ft, Polaris65.
    6/30, Temp83F (28.3C), pH 7.8, FC 2.8 ppm, CC 0 ppm, TA 100, CH 80, CYA 40, -B4O7 30, CSI-0.17.
