Results 1 to 9 of 9
Thread: Leaking booster pump
    Dallas, TX
    227
    My booster pump is spewing water from the front of the unit, farthest Gro the motor.
    Here is a video:
    http://www.youtube.com/watch?v=Rf8NaIb4 ... ata_player
    Here is a picture I where it is leaking
    Can this be fixed with out buying a new unit? It's less than two years old.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Leaking booster pump
    Is it coming from the seem or a crack in the plastic?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Dallas, TX
    227
    It's coming from that inch long piece of plastic that points to 4 oclock between the two bolts, from the tip of that piece is what it looks like. Not from the seam that the bolts hold together.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Can it get hit by something, like the mower? I'd say the front half has to changed.
    Dallas, TX
    227
    No, thats the weird thing. It in an enclosed fence area. Nothing to hit it.
    Any idea where to get a new front?
    Aug 2007
    near the swamp
    806
    you must change the volute, Polaris part# P5
    Dallas, TX
    227
    Ok great thanks. An tips on doing that or is it pretty self explanatory. Never worked on one of these before.
    Aug 2007
    near the swamp
    806
    It's very easy, remove the 6, 1/2" bolts&nuts, then pull apart, you may need to replace the o-ring also, then smear some RTV silicone around new volute, put new o-ring on, then put back together
    Dallas, TX
    227
    Worked great. Replaced the hose connectors too and everything is leak free. Thanks for the help!
