Thread: What would cause pump pressure to do down?
    Sep 2011
    Atlanta Ga
    310
    A few days ago the pressure guage said 13, which is has been since in installed it a month ago. Today it is 11.5. I have not backwashed. What would cause pressure to go down?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    May 2009
    Dallas, TX
    782
    Re: What would cause pump pressure to do down?
    2 possibilities:
    Air in the line (suction leak)
    Blockage (skimmer basket full)
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    crud in the impeller.
    Sep 2011
    Atlanta Ga
    310
    I didn't know what an impeller was, but just found out on wikipedia. So if that is the cause, is there any way to fix it? The pump is only one year old.
    When the leak detector guys came out they said there was a small suction leak in the line coming from the skimmer. They said it was not big enough to cause water loss but would get a little air into the system. Maybe that is is slowly getting worse.
    They fixed the more serious leaks that were causing water to go down. I guess I will eventually need to dig up that line and fix it.
    27000 gallons
    Pool built in 1971.
    Apr 2011
    Murrieta, CA
    2,360
    Depending on the pump it may be easy to check/clean the impeller. I recently had an oak tree drop lots of stuff into the pool and it got by both baskets. The tree droppings look like worms when wet, pollen pods for lack of a better term, clogged the impeller. On my pump (Duraglass) it's easy to get to the impeller and clean it out. It isn't hard to do, but you need to separate the motor from the housing to get access to the impeller. The impeller is connected to the motor shaft.
