Results 1 to 7 of 7
Thread: The Liquidator question before I buy one..
    I have no way to keep it out of the sun. Is that a prob... Are can I just build a cover over it.. Are a box.. I have a shed but is 30 feet from pump... Any thoughts before I pull the trigger?
    33x52 AGP 25600 Sand filter 1.5 HP Hayward
    30,426
    Re: The Liquidator question before I buy one..
    The LQ is made from semi-tranparent plastic so I would certainly protect it from the sun....both for the uv degradtion of the plastic and possibly to help protect the chlorine as well.
    If it won't look horrible, I might consider a 3-sided shelter facing away from the elements with a roof over it. Just the roof will be great, though.
    do I need to change the needle value as people here are talking about are will it hookup an run with what comes with it..
    http://pstpoolsupplies.com/hasa-liquidator-updated.aspx
    Mar 2007
    San Rafael, CA USA
    12,082
    The 3/8" upgrade will help help prevent "white stuff" which is calcium carbonate formation. It likely still forms a little, but with the larger openings it flows through instead of getting stuck. Make sure your CSI doesn't get too high and you could use 50 ppm Borates as well since that seemed to help in many, but not all, cases.
    22,551
    The 3/8" upgrade certainly makes the unit operate better but it's not completely required.
    However, since you have an aboveground pool, you may want to consider it because they tend to have very low suction head, and therefore without the upgrade you have to partially close off the suction valve to get enough suction head to get the unit to work well.
    Dec 2010
    San Diego, CA
    1,137
    The needle valve is nice for fine tuning the rate of flow with the LQ. But it's not absolutely needed.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I painted my liquidator with white spray paint for use on plastics. I taped a stripe on each of the 4 panels and marked a line for each of the 8 gallons of chlorine that the unit can hold.
    I also installed the Hayward Needle Valve to adjust the flow.
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
