Thread: Alternate connection for my new Polaris 280
    Jul 2010
    Richardson, TX (Dallas suburb)
    52
    I just got my new Polaris 280 and it comes with a 1 1/2" quick connect. My problem is that my Booster Pump return line is only either 1/2" or 3/4" female. I can't seem to get any info about how to connect from anyone, including the guys at the pool stores. Is there an adapter? Or what should I do?
    Brian, Richardson TX. 25K Plaster Pool, 1.5 HP Pump, Polaris 280 w/ 3/4 HP Booster Pump, 325 sq ft Cart Filter. This is my 3rd pool to convert to BBB method.
    woohoo's Avatar
    Feb 2012
    Collierville, TN
    33
    Re: Alternate connection for my new Polaris 280
    Looks like you need something like this. This one is a Coupling, 1-1/2 NPTF x 3/4" NPTM. You can find them at most on line stores that sell Polaris parts. Maybe a local plumbing supply house. I could not find the fitting on line at Home Depot or Lowes for you. Good luck with your search!
    33,000 Gallon Vinyl Liner In-Ground Pool
    Intelliflo VS Pump; Triton II TR100 Sand Filter with Plumbed Waste Line
    IC40 SWG Cell; Easy Touch 4 Control Panel; Polaris PB4-60Q Halcyon Booster Pump
    Polaris 280 Automatic Cleaner; Dedicated return line; 1/2 Full Beer, Something on the Weber;
    AND, most importantly a TF100 Test Kit and a SpeedStir.
    Jul 2010
    52
    Thanks. That is exactly what I found.
    woohoo's Avatar
    Feb 2012
    Collierville, TN
    33
    Glad you solved your problem.
