Results 1 to 14 of 14
Thread: Why does pool school say to test CH weekly?
    Sep 2011
    Atlanta Ga
    310
    Why does pool school say to test CH weekly? I thought it stayed the same unless you add water.
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Feb 2012
    Phoenix, AZ
    728
    Re: Why does pool school say to test CH weekly?
    CH can go up due to curing of plaster, or from cal-Hypo. It is important to maintain your CH levels because if it gets too high it can cause scaling (which can be really expensive to fix). Low CH can actually start to absorb calcium out of the pool walls and floors causing damage. Partial Drains and of the pool or reverse osmosis are the only ways to lower CH.
    Feb 2008
    Denton, TX
    5,061
    After a while, once you get used to the composition of your pool water, you may not need to test CH so often. But if you have: 1.) plaster less than 1 year old, 2.) cal-hypo that you use frequently, 3.) fill water that is high in calcium, you probably need to test once per week.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I agree with 1 & 2 but I have high CH fill water (~300 ppm) and I have found that the CH rise is very predictable and occurs fairly slowly so I usually test bi-monthly.
    Mark
    30,414
    I would encourage anyone who first starts to test and manage their own pool to do CH test weekly until you verify that it is stable. In most pools, it is quite predictable and you can drop back to whatever your comfort level is.
    As you open each Spring, I would again suggest a weekly test for a couple or three weeks so you can verify it's stability once more.
    Sep 2011
    Atlanta Ga
    310
    Thanks for the info. The fill water here here is low in calcium. Before adding chemicals it was 50. I added calcium and gradually brought it up to 250. I am not using cal-Hypo, and it is an old plaster pool so I don't expect it to change based on what has been said here, but I'll test weekly for a while and see if it is stable.
    27000 gallons
    Pool built in 1971.
    30,414
    Nice work, Tom, you have become a BBB'r pretty quickly!
    Feb 2011
    Petaluma, Ca
    665
    My ch has been at 350 since we filled. It has never changed. I did have my pool cover pump pumping the water into the pool over the last week to lower my salt level some, got 3" of rain. I'll test today to see if the ch went down also.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Sep 2011
    Atlanta Ga
    310
    Thanks.
    27000 gallons
    Pool built in 1971.
    Feb 2011
    Petaluma, Ca
    665
    After a couple days of mixing in the rain, my ch is now 310, down from 350.
    Sep 2011
    Atlanta Ga
    310
    I don't understand how this works. Does that mean that over 10% of the pool water was replaced by rain, or does it mean that the calcium is somehow removed from the water, or does it mean something else that I don't understand?
    27000 gallons
    Pool built in 1971.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by TomAtlanta
    It means that calium-rich water was replaced by calcium-free rainwater and/or the pool level went up with the rain, diluting it.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    it just means that rain water has zero calcium in it so therefore when it rained it naturally dropped the CH level. it's my understanding based on reading this forum that calcium hardness never leaves the water unless there is reverse osmosis, partial refill or splash out.
    for example last week, i tested my CH before we were supposed to get some substantial rain. my CH was about 450 ish and i was able to capture a bit over 4 inches of rain and it lowered my CH to 400 ish. pretty close to where it needs to be. that's down from nearly 550 in early december before all of the rains have come.
    hope this helps.
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    Feb 2011
    Petaluma, Ca
    665
    I was surprised how much it went down, in hind site I prob should have left it at 350 because at 310 my csi is approx -.50.
