Results 1 to 13 of 13
Thread: My new build
    Dec 2011
    Austin, TX
    38
    My new build
    My build is underway. HOA approval was obtained. I checked with by pool builder to verify that permits had been pulled. He indicated that, where necessary, yes. The permits required in my MUD are the plumbing for gas lines and the auto fill unit, and that was it. There is no electrical permit or inspection required and no pool inspector required. I double checked with a neighbor of mine who just finished his build. He confirms the same, except indicates he didn't even need plumbing. Kinda loosey goosey don't y'all think.
    Would anyone have any suggestions as to how to be sure that all is well and safe. the electrician is going to be a master electrician, that I will verify, but who checks him? Would anyone go so far as to hire an independent home inspector to check that work?
    Built 2012: 14x28' free formed IG gunite with 4 person spa. 11,000gal, Hayward 2 speed Tristar pump, Hayward 420sq ft cartridge filter , auto tablet chlorinator (I use BBB), 250BTU Hayward heater, quartz pebble finish, LED lighting
    Feb 2008
    Denton, TX
    5,061
    Re: My new build
    Does the builder that you have hired come well recommended to you? Have you seen examples of his work elsewhere?
    What state do you live in? Electricians in most states are required to be licensed and you can check this on your own on the internet usually.
    Dec 2011
    Austin, TX
    38
    Re: My new build
    We live in Austin, Texas. I checked him out with several previous customers. I will plan on checking the license of the electrician.
    Dec 2011
    Central Texas
    19
    Re: My new build
    Congratulations on the new pool
    Do you live in the City of Austin? If so, you have to have Building, Electrical, and Plumbing permits. We are in the process of getting a pool (assuming the rain stops and ground dries out) and those permits we're required.
    Good luck
    20,000 gallon in-ground plaster pool. Sta-rite cartridge filter, Sta-Rite Max-E-Glas II pump 1 1/2hp motor, Caretaker pool cleaner, Teledyne LAARS series 2 ESC natural gas heater 250,000 BTU. Solar Pool cover, Intermatic Timer with heater switch. Two very happy kids!
    Dec 2011
    Austin, TX
    38
    Re: My new build
    No I do not live in the city of Austin, I am between Round Rock and Austin. It's Williamson County.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: My new build
    a couple of things that permits or not, you should be self-aware of and check on your own to make sure they are done:
    1. Bonding. For safety and comfort make sure that all of your bonding is done correctly. This means simply making sure everything at the pool and for at least 5' around the pool are "connected" to each other in terms of conductivity so they are all at the same electrical potential. All metal, light niches, ladders and rebar or metal reinforcement in the deck need to be connected via a #8 solid copper wire. If there is not going to be any reinforcing metal in the deck, ask for some for this purpose. This will remove any chance that you will recieve any shock or tingling when touching the deck and water at the same time (or any other two parts of the pool). Even if its not required in any code... do this. Educate yourself and make sure its done right or it can be a bear to correct after pool completion.
    2. If you are going to have an auto-fill make sure they use a backflow prevention device on the supply line to the filler. Somewhere in the midwest a poopy diaper in a pool was traced to be the cause of a whole neighborhood getting ill.
    3. Fencing and gates: Make sure your pool is enclosed in some sort of fence, (if your backyard is fenced that will do it) and that the gate auto-closes and latches. Hate to wake up some morning and find a child in your pool (its awful to even speak of it happenning but it does so safety first!).
    Good luck with your build that looks like an awesome layout!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    419
    Re: My new build
    On the electrical I did my own, with the help of a friend whom is a licensed electrical contractor.
    Basically what I learned is that there is a difference in hooking up your main run to the pool vs the electronic pool controls. Otherwise your electrician can do all your work, but hooking up and programming the pool controls is better left to someone that only does pools and only works on the type of control you have. Again I did all my own, but had to read the manuals etc. Otherwise your you are paying your contractor to learn pool controls.
    Also need a GFI outlet within like 8' of the side of the pool
    Bonding in pool rebar around pool and back to pump and ic-40. As all need same bond.
    All circuit breakers should be GFCI
    Otherwise the design of your pool look great.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Dec 2011
    Austin, TX
    38
    Re: My new build
    lershac and blakeusa, thank you for your replies. The dig is done ,the rebar for the shell is in, and the plumbing is done today. I see the bonding. The decking will be concrete, so I assume there sill be additional rebar placed, after the gunite is sprayed.
    I am having trouble loading pics. I have so many great ones and I am interested in sharing them with y'all, the loader keeps telling me they are too big. I take them with a simple lousy camera with nothing fancy...I will place a new post elsewhere in the forum, but can anyone reading help.
    Doesn't everyone love to see other build pictures!!!???
    Chris
    Ashbourne's Avatar
    Western Piedmont, NC
    109
    Re: My new build
    Chris, if you have Paint (go to Start > All Programs > Accessories > Paint) you can size your pictures down before uploading them.
    18x36 IG Vinyl, 8.5 deep, 28K, Hayward C4025 SwimClear Filter, Hayward SP2607X10 Super Pump 1HP
    Dec 2011
    Austin, TX
    38
    Re: My new build
    Well my build is progressing in a timely manner. We broke ground on 3-12-12 and we are at the final stages. I am not super computer savvy and have had trouble uploading pics.
    I have now uploaded pics to a photobucket. Please enjoy and comment on my photos from lawn to concrete hole in the ground.
    We are at plumbing and electrical. Should only be a bit more until I am no longer "under construction" as my sig indicates!
    I have read pool school several times and looking forward to learning more from y'all. Test kit is ordered!
    Thanks
    Chris
    http://www.photobucket.com/boston2austin
    Feb 2012
    Winston Salem NC
    161
    Re: My new build
    If you click in the img code box on photobucket you can paste the link here.... like this.... (I have doctors orders to stay off of my feet and wear funky braces for 6 weeks do to a failing arches so I figured I would help you out!)
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Dec 2011
    Austin, TX
    38
    Re: My new build
    Thanks "head gamez!" I wish I could have done that all along! I hope our administrator doesn't mind the large post. I know folks love to scroll through other peoples pics though!
    Feb 2012
    Winston Salem NC
    161
    Re: My new build
    That is the great part of hosting the images with photbucket (or similar).... It is not taking up space on TFP.
    The only thing I hate about the image hosting sites is that my company blocks most of them.... unless I am on VPN!
    Tigershark QC Robot
