Results 1 to 17 of 17
Thread: Safe way of Adding CYA without over adding?
    Mar 2012
    Maryland
    87
    I tested for CYA using the CYA reagent and vial with the black dot on the bottom. I transfered the liquid to the vial and noticed the water was so clear I could see the black dot even if i filled it beyond the graduation level on the vial (30). So this indicates I have at least <30 ppm of CYA. The water wasen't even the slightest cloudy beyond 30. So I can only asume that it could be 20, or 10 or 0. Based on the pool calculator on a 13,500 gallon pool to raise by CYA by 10ppm It indicates I need to add 18 oz by weight of CYA or 19 oz by volume. I'm thinking (just to be safe). I should add cya in increments of 10ppm until it registers on the test (is supposed to take a week). Then I can go from there.
    I'm also curious on the values the pool calculator is giving me. OZ is a measurement of mass. So I add 18 oz? how do I add 19oz by volume? What does that mean????
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Safe way of Adding CYA without over adding?
    by volume means you use a normal measuring cup. 8 oz by volume = 1 cup.
    Mar 2012
    Maryland
    87
    Quote Originally Posted by Melt In The Sun
    So pretty much If I'm using this stuff HTH Pool Stabilizer and Conditioner (http://tinyurl.com/86mdvv3). I need to use 2.37500 cups of the stuff to bring a 13500 pool to 10 cya?
    Yes, 2 3/8th cups of that will be right around 10 ppm of CYA.
    Keep in mind that granular CYA can take up to a week to fully dissolve and show up on the test. Generally what you want to do is add about 2/3rds of the total amount you think you need, wait a week, test to see where you ended up, and then make a second adjustment from there.
    Mar 2012
    Maryland
    87
    Mar 2012
    Maryland
    87
    OK, I'm getting different readings. I just spoke with HTH over the phone. They indicated to increase the cya to 30 ppm on a 13500 pool I need to add 62 oz of hth stabilizer. But the pool calculator is showing me 56oz by volume?
    30,421
    It doesn't matter. The accuracy of the test is plus or minus 10ppm at best so you waon't be able to detect the difference.
    YOur CYA measurements do not have to be precise. If you shot for 20ppm and get 25ppm, that's fine.....30 is not a deal breaker, either. If you shoot for 20 and get 40, well.....really?
    Once you begin your shock process, your FC dosages can be a little more accurate but, again, they do not have to be of the precision you are targeting.
    Keep all your info as you start this in one thread.
    I have forgotten, have you done a recent pH test?
    Mar 2012
    Maryland
    87
    Yep, Yesturday it was 7.2.
    22,550
    The difference is probably that the Pool Calc uses 100% cyanuric acid in its calc and HTH probably used the actual percentage in theirs.
    But as Dave said, a difference that small really doesn't matter.
    Mar 2012
    Maryland
    87
    It kind of makes me wonder if we need to find a chemist to do some complex mathematical calculations to determine how much CYA do you actually need? Maybe there's a sweet spot that is perfect and will cause maximum TC benefit and minimize TC dosages?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by steppinthrax
    No two pools have the same climate, bather load or fill-water chemistry. All you can do is take the vales in the chart and see what works best in your pool.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    In our efforts to be as precise as possible, we tend to overlook that we can only crudely calculate the amount of water involved. A water level difference of 1 inch for a 15' x 30' pool is more than 250 gallons. The precision of trying to dose to the ounce or CC or drop, or, whatever, is still limited by how closely we know the amount of water to which we are applying it.
    38,290
    Quote Originally Posted by Ohm_Boy
    Excellent point ... I would be amazed if I was within 1000 gallons. With the freeform and variable depth in ground pools, this certainly can be a challenge.
    You can almost get a better idea of the volume by dosing certain chemicals, measuring the results before and after, and playing with the pool calculator pool size to get the numbers close.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    You are absolutely correct; it's a big reason for doing one's own testing and pool maintenance. You get to know your pool, and develop a feel for how it behaves and what it needs.
    Mar 2012
    Maryland
    87
    OK, I got the HTH stabilizer. It's 96% Cyanuric Acid, I guess that's why their dosage is higher. Anyway I put two cups in a sock and hung it over my return. In roughly 2 hours it's mostly all out from the sock. So I need to wait a week before I test?
    30,421
    Well, no. You can test anytime you want to check yourself. Experience on the forum seems to be that the CYA test isn't valid for anywhere from 2-7 days.
    Mar 2007
    San Rafael, CA USA
    12,082
    It could also be that their product is less dense, possibly with larger granules, than what we assumed. Measuring by weight will always be more accurate than measuring by volume since one must make assumptions about bulk product density and that will vary depending on the size of the granules and on how well the product is packed/tapped when measuring.
