Results 1 to 8 of 8
Thread: Want to see pictures of peristaltic pump installations
    Hi all and thanks to TFP, I have scrapped my PB's original plans for ozone, fusion2, and inline chlorinator in favor of a Stenner 45MHP2 pump...I also became a lifetime supporter after just a few posts due to gobs of useful info you all have thrown at me.
    Now I just need some suggestions on how to make this happen since the PB doesn't know much about this (surprise, surprise).
    I have a 30k pool in NC with 5 deckjets but no spa or other water features. We are installing a Jandy CV340 cartridge filter, 2 speed Jandy Stealth pump and the Stenner. I saw some of the photos and read through this thread, but what would you suggest for a completely "new install" of this setup?
    I wondered if there was a plumbing diagram (or at least your suggestions) that I could show the subcontractors just to make sure it's all done right.
    It seems that the injector line should be located after all equipment, is that correct? I just want to be sure these guys don't mess up my setup as the previous equipment pad was an utter mess.
    Sorry for the "basic" questions, but I truly appreciate your help...thanks!
    Charlotte, North Carolina, 30k, in-ground concrete (built 2001, remodeled 4/2012), PebbleSheen Blue Aqua, Polaris 360, Jandy 1.0 HP Dual Speed Stealth Pump, Stenner Pump 45MHP2 220v - 1/4" black tubing mounted on 15 gallon UV Gray tank, Jandy CV340 CF, CMP deck jets x6. TF-100.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Want to see pictures of peristaltic pump installations
    Hi, welcome to TFP! Yes, Stenner pump should be the last thing before the return. Someone should be posting their pictures in the next day or two.
    Love TFP? Become a
    TFP Supporter!
    22,551
    If you look through my "defected to the dark side" thread you'll see pics of my setup as well as a few others. The injection point should be the last thing in the return line before going to the pool. However, if read through the thread you'll see the discussion about placing it elsewhere and the possible ramifications.
    Oct 2008
    Bonita Springs, Florida
    84
    Bama -
    Can you post the link for the "deflected to the dark side" thread?
    Thanx.
    SW FL, 19K IG with spillover & cage, Goldline Pro-Logic PS-8, Hayward Sense & Dispense, Hayward Swim Clear 4025, Hayward Ecostar VS pump, Stenner MA pump, Aquabot, Hayward Aquarite SWG, Palin Pooltest 9, Helicol Solar.
    22,551
    Here you go!
    I think the first pics are on page 4.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    I just took pics of mine with the iPad, now I have to figure out how to post them from it.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    This is the injection point right after the water exits the filter to return to the pool. Mine works, but looks kinda redneck. I used a T with 1/2 thread and sliced it in half. I then used hose clamps and two part epoxy to attach it and make it water tight. It is ugly, but it is water tight and works.
    [ img ]://i219.photobucket.com/albums/cc258/dejaymiller2/Stenner/IMG_0086.jpg[ /img ]
    On the wall close to the pump is the injection pump. On the wall on the opposite side is the timer for the pump.
    [ img ]://i219.photobucket.com/albums/cc258/dejaymiller2/Stenner/IMG_0077.jpg[ /img ]
    On the ground is my 15 gallon chlorine tank. Most of the tank is below the ground to keep it cool and help slow the degradation of the chlorine. Above the tank on the wall is the timer.
    [ img ]://i219.photobucket.com/albums/cc258/dejaymiller2/Stenner/IMG_0076.jpg[ /img ]
    Not shown well in the photos is the 1/4 line that goes from the buried tank to the pump and then from the pump to the T fitting in the pool plumbing.
    Installing the plumping for the pump was much easier for me then the wiring for the timer.
    Jandy 2 speed pump
    thanks for the pictures and the link...really helped me get a handle on the process....will post pictures of my hook up once completed...
