Results 1 to 9 of 9
Thread: How do i go by building a new stand for my sand filter?
    I have a 16" Hayward S166T sand filter; the base was not usable so it got thrown away. How would I go by making a new one. I looked, cheapest i can find is 70 dollars for one.
    22,550
    Re: How do i go by building a new stand for my sand filter?
    Masonry mix. Build a frame out of 2x4's and fill it with mortar mix and set the filter down in it. Trowel it out smooth and let it cure. Perfect custom fit!
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Will it fit into a car wheel? I don't remember exactly how deep my filter sat into it's frame.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I'd use bricks or 'pavers' so that you can access the drain plug.
    Luv& Luk
    -Ted
    Aug 2011
    Metro Atlanta, Georgia
    161
    The outside circumference of my base is 48", which gives a diameter of 15.29" . The drain is a little more than the width of my thumb from the base, the base is about 5 inches tall.
    If rust is not an issue, I would pick up an old 15" tire rim with at least a four inch set back (distance from the rim edge to the bolt plate/holes on the back of the rim). There might be an issue with how high it sits.
    Another option would be to cut a hole in plywood, using a 7.64" radius and build legs with 2x4s, blocks, bricks, whatever.
    Disclaimer: I measure once and cut a lot, verify these measurements before proceeding!
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    I have been making one out of treated wood after doing some thinking. Thanks all of you for all of the suggestions.
    Mar 2007
    4,160
    Don't forget to allow easy access to the drain plug
    Luv& Luk
    -Ted
    Quote Originally Posted by waste
    I added that in the design.
    Dec 2010
    San Diego, CA
    1,137
    And don't forget to take and post pics
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
